嗨,我正在尝试在ubuntu上安装xilinx sdk,在安装启动时,它说Ubuntu 16.04需要额外的库。这些库需要什么?
我目前在安装后遇到这样的错误 /media/achalla/BE5003CF50038CF9/Anjaneyulu/Ubuntu/Program_Files/SDK/2017.1/bin/unwrapped/lnx64.o/rdi_xsdk:加载共享库时出错:/media/achalla/BE5003CF50038CF9/Anjaneyulu/Ubuntu/Program_Files/SDK/2017.1/ lib / lnx64.o / libprotobuf.so.7:无效的ELF标头 以上来自于谷歌翻译 以下为原文 Hi, I am trying to install xilinx sdk on ubuntu, On start up of installation it says additional libraries required for Ubuntu 16.04. What are the libraries require ? I am currently getting a error like this after installation /media/achalla/BE5003CF50038CF9/Anjaneyulu/Ubuntu/Program_Files/SDK/2017.1/bin/unwrapped/lnx64.o/rdi_xsdk: error while loading shared libraries: /media/achalla/BE5003CF50038CF9/Anjaneyulu/Ubuntu/Program_Files/SDK/2017.1/lib/lnx64.o/libprotobuf.so.7: invalid ELF header |
Hi@anjaneyulu.challa9,
如果您在启动SDK时遇到问题,请尝试以下答案记录中提到的建议,看看是否有帮助。 https://www.xilinx.com/support/answers/67580.html https://www.xilinx.com/support/answers/69263.html 另外,尝试使用sudo权限启动SDK,看看它是否有帮助。 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @anjaneyulu.challa9, If you are seeing the issue while launching SDK then please try the suggestions mentioned in below answer records and see if it helps. https://www.xilinx.com/support/answers/67580.html https://www.xilinx.com/support/answers/69263.html Also, try launching SDK with sudo permission and see if it helps. Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
如果您在启动SDK时遇到问题,请尝试以下答案记录中提到的建议,看看是否有帮助。 https://www.xilinx.com/support/answers/67580.html https://www.xilinx.com/support/answers/69263.html 另外,尝试使用sudo权限启动SDK,看看它是否有帮助。 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @anjaneyulu.challa9, If you are seeing the issue while launching SDK then please try the suggestions mentioned in below answer records and see if it helps. https://www.xilinx.com/support/answers/67580.html https://www.xilinx.com/support/answers/69263.html Also, try launching SDK with sudo permission and see if it helps. Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1171浏览 1评论
585浏览 1评论
451浏览 1评论
2005浏览 0评论
729浏览 0评论
GMT+8, 2024-12-23 15:25 , Processed in 1.560152 second(s), Total 80, Slave 64 queries .
