尝试运行SDK或Vivado的安装程序时,出现“身份验证错误:发生了未知异常。请验证您的用户ID和密码,然后重试”
我可以登录该站点,另一位同事可以登录该站点。 我们可以下载安装程序,但是当我们尝试安装时,我们在安装的这一点上都有相同的错误。 用户ID和密码验证登录但无法安装。 想法? 是否存在已关闭的身份验证服务器? 以上来自于谷歌翻译 以下为原文 When trying to run the installer for either SDK or Vivado, I get "Authentication error: An unknown exception occurred. Please verify your user id and password and try again" I can log into the site and another co-worker can log into the site. We can download the installer but when we try to install we both have identical errors at this point in the install. User IDs and passwords verify to login but fail to install. Ideas ? Is there an authentication server that is down ? |
9个回答
这是窗户吗?
当我禁用“服务器”服务时,我曾经遇到过这些错误。 或者当我安装了代理/防火墙时。 你有更多的日志吗? 检查此AR: https://www.xilinx.com/support/answers/60118.html vitorian.com ---我们这样做很有趣。 总是给予赞誉。 如果您的问题得到解答,请接受解决方案。我不会回复个人信息 - 请改用论坛。 以上来自于谷歌翻译 以下为原文 Is this windows? I used to have these errors when I had the "Server" service disabled. Or when I had a proxy/firewall installed. Do you have more logs? Check this AR: https://www.xilinx.com/support/answers/60118.html vitorian.com --- We do this for fun. Always give kudos. Accept as solution if your question was answered. I will not answer to personal messages - use the forums instead. |
我们中的一些人似乎在另一个线程中遇到此问题。
Xilinx还没有任何消息,但我相信情况确实如此.https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2016-4-fails-to-install-due-to-server -500-误差期间/ TD-p / 775418 /页/ 2 以上来自于谷歌翻译 以下为原文 Several of us appear to be having this problem in another thread. No word yet from Xilinx, but I believe that is exactly the case. https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2016-4-fails-to-install-due-to-server-500-error-during/td-p/775418/page/2 |
我也有同样的问题。
在西海岸和东海岸的3个系统中进行了测试。 我收到“身份验证错误:发生了一个未知异常”。 但是,网络登录似乎没问题。 以上来自于谷歌翻译 以下为原文 I'm also having the same problem. Tested across 3 systems in west coast and east coast. I'm getting "Authentication error: An unknown exception occured". However, the web logins appear to be fine. |
我在西海岸也遇到了同样的问题,可以在线登录。
很高兴我不是唯一一个。 以上来自于谷歌翻译 以下为原文 I'm also getting the same issue here on the west coast and can login online. Glad I'm not the only one. |
身份验证服务器似乎重新联机。
安装人员现在正在工作。 以上来自于谷歌翻译 以下为原文 The authentication servers seem to be back online. Installers are working now. |
大家好,
我们确实在服务器端出现了问题,服务已经停止了一段时间,但是现在已经对它进行了排序,现在一切正常。 对由此造成的任何不便表示歉意。 祝你今天愉快。 亲切的问候, 阿纳托利柯伦 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello All, We had indeed an issue at the server side where the service was down for a while, however this is now sorted and everything is working now. Apologies for any inconvenience caused. Have a nice day. Kind Regards, Anatoli Curran Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好,
这正是我现在遇到的问题。 服务器再次关闭? 我曾尝试多次运行安装程序。 我在Ubuntu系统上运行2017.4 vivado web pack。 以上来自于谷歌翻译 以下为原文 Hello, This is exactly the issue i am having now. Is the server down again? I have tried to run installer several times. I am running 2017.4 vivado web pack on an Ubuntu system. |
这是一个持续的问题吗?
我想在Ubuntu 16.04发行版上安装2017.4 Vivado WebPack。 我遇到了同样的问题。 我可以在线验证凭据,但我无法通过安装程序。 以上来自于谷歌翻译 以下为原文 Is this an ongoing issue? I am trying to install 2017.4 Vivado WebPack on an Ubuntu 16.04 distr. I am getting the same issue. I can authenticate credentials online, but i cannot through the installer. |
我在Linux和Windows上都遇到了同样的问题。
任何解决方案呢? 以上来自于谷歌翻译 以下为原文 I am having the same issue on both Linux and Windows. Any solution yet? |
2308 浏览 7 评论
2719 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2355 浏览 15 评论
633浏览 1评论
1685浏览 1评论
444浏览 1评论
203浏览 1评论
653浏览 0评论
GMT+8, 2024-9-22 06:59 , Processed in 1.374649 second(s), Total 62, Slave 56 queries .
