扫一扫,分享给好友
我已经安装了Vivado 2017.3
当我打开电脑时,我收到了Vivado 2017.3.1更新的通知。 按下“下一步”按钮后运行更新程序时,我进入附件中显示的页面,该页面为空白,“下一步”按钮不执行任何操作。 以上来自于谷歌翻译 以下为原文 I have installed Vivado 2017.3 when turned my computer on i got a notification for Vivado 2017.3.1 update. When running the updater after pressing Next button i get in the page shown in the attachment, wich is blank and Next button does nothing. |
3个回答
你能检查一下这个AR吗?
https://www.xilinx.com/support/answers/70025.html 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 can you please check this ARs https://www.xilinx.com/support/answers/70025.html Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨@ mifragiadakis,
你可以正确关闭你的电脑,然后再次检查吗? 问候, hemangd 以上来自于谷歌翻译 以下为原文 Hi @mifragiadakis, Can you properly shut down your PC and then check once again? Regards, hemangd |
嗨@mifragiadakis,
作为解决方法,您可以从此Xilinx链接下载Vivado 2017.3.1的更新。 (更新1) 下载后使用管理员权限提取并运行.exe。 问候,prathikm ----------------------------------------------- ---------------如果提供的信息有用,请将相应的答案标记为“接受为解决方案”。将“Kudos”发送到您认为有用并回复的帖子.-- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi @mifragiadakis, As a workaround, you can download the update for Vivado 2017.3.1 from this Xilinx link. (Update 1) Just extract and run the .exe after download with admin privileges. Regards, prathikm -------------------------------------------------------------- Please mark the appropriate answer as "Accept as solution" if information provided is helpful. Give 'Kudos' to a post which you think is useful and reply oriented. -------------------------------------------------------------- |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3414 浏览 0 评论
2506 浏览 15 评论
2309浏览 1评论
649浏览 1评论
514浏览 1评论
2062浏览 0评论
790浏览 0评论
GMT+8, 2025-2-12 02:28 , Processed in 1.107611 second(s), Total 45, Slave 40 queries .
