我已获得SDSoC的试用许可证并将其加载到许可证管理器中;
它说“装载成功”。 然后我启动SDSoC并弹出一条错误消息,请参阅附件。 然后我再次加载它(许可证管理器说一切都很好),然后再次启动SDSoC,并得到相同的错误消息。 任何想法为什么它不能正常工作? 以上来自于谷歌翻译 以下为原文 I've got my trial license for SDSoC and loaded it with the License Manager; it said "loaded successfully". Then I start SDSoC and it pops up an error message, see the attachment. Then I'm loading it again (License Manager says everything's fine), and then starting SDSoC again, and getting the same error message. Any ideas why doesn't it work properly? |
你好@ fandrei,
看起来该工具无法检测到您的SDSoC 60天评估许可证。 您能否分享一份XINFO报告的副本(在您看到此许可错误的机器上生成)进行检查?可以通过在Vivado TCL控制台中运行“report_environment -file xinfo.txt”命令来生成Xinfo.txt 。 如果您有任何疑问,请告诉我。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @fandrei, Looks like the tool can't detect your SDSoC 60-day Evaluation license. Can you please share a copy of your XINFO report (generated on the machine where you are seeing this licensing error), for examination? Xinfo.txt can be generated by running the "report_environment –file xinfo.txt" command in Vivado TCL console. If you have any questions, please let me know. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
我通过多次重新加载许可证并重新启动来解决此问题。
不过不确定是什么原因。 以上来自于谷歌翻译 以下为原文 I've fixed this problem by re-loading the license several times and rebooting. Not sure what was the reason, though. |
2522 浏览 7 评论
2885 浏览 4 评论
2341 浏览 9 评论
3439 浏览 0 评论
2524 浏览 15 评论
2675浏览 1评论
675浏览 1评论
539浏览 1评论
826浏览 0评论
GMT+8, 2025-3-10 07:36 , Processed in 1.322654 second(s), Total 78, Slave 62 queries .
