大家好,我正在从16700系列转换到16800系列逻辑分析仪。
对于我以前的16700 LA,我可以通过配置“File Out”功能在每次运行后自动保存测量数据文件。 但是,对于我的16800系列,我在XP系统上安装了这个LA,并且具有版本5.10的逻辑和协议分析软件,但是我找不到任何与“文件输出”类似的功能。 那么有没有人知道如何在每次测量后自动保存数据文件而无需进入菜单并单击“保存”或“导出”? 谢谢你的建议! 以上来自于谷歌翻译 以下为原文 Hi all, I'm doing a transition from 16700 series to 16800 series logic analyzer. For my old 16700 LA, I'm able to automatically save the measurement data file after each run by configuring the "File Out" function. However, for my 16800 Series, I have this LA on XP system and have the Logic and Protocol Analyzer software ver 5.10 but I'm failed to find any similar function as "File Out". So does anyone know how to save data files automatically after each measurement without go to the menu and click "Save" or "Export"? Thanks for your advice! |
首先,您应该获得最新版本的SW,目前为5.70。
此功能在此过程中的某处添加,但在与16700不同的位置。如果它在菜单中,单击运行/停止 - >运行属性...您应该会出现一个带有“保存选项”的对话框,这将允许 您可以使用增量文件名保存为6种格式之一的文件。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦威廉希尔官方网站 呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决威廉希尔官方网站 问题的最快方式。 以上来自于谷歌翻译 以下为原文 First, you should get the latest version of the SW, currently 5.70. This capability was added somewhere along the way, but in a different place from the 16700. If it's in your menu, click Run/Stop -> Run Properties... You should get a dialog box with 'Save Options', which will allow you to save into files with an incrementing file name, in one of 6 formats. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
1360 浏览 0 评论
2409 浏览 1 评论
2245 浏览 1 评论
2095 浏览 5 评论
2990 浏览 3 评论
1346浏览 1评论
807浏览 0评论
1128浏览 0评论
1361浏览 0评论
GMT+8, 2025-2-9 05:38 , Processed in 1.201244 second(s), Total 75, Slave 59 queries .
