我们一直在使用Agilent VNA不确定度计算器电子表格,让我们了解我们测量的设备的不确定性。
有关单端口校准的问题:目前您必须从电子表格中选择您的VNA(带宽和平均值),然后选择校准类型(全双端口,增强响应或响应),没有单端口 校准。 我们是否可以使用全双端口校准中的S11不确定性来覆盖单端口校准的不确定性? 或者我们是否必须执行全双端口校准来测量单端口设备? 注意:查看各种Agilent VNA的手册,它们表明在计算S11(mag)不确定度时,S21和S12的稳定性中有一些术语。 希望有人可以帮忙...... 以上来自于谷歌翻译 以下为原文 We have been using the Agilent VNA Uncertainty Calculator spread sheets for a while now to give us an idea of uncertainty for the devices we measure. A question came up with regards to a single port calibration: At present you have to select your VNA (bandwidth and averaging) and then type of calibration (Full two port, Enhanced Response or Response) from the spread sheet, there is no Single port calibration. Can we use the S11 uncertainty from the Full two port calibration to cover the uncertainty from a Single port calibration? Or do we have to carry out a Full two port calibration to measure a single port device? Note: Looking a the manuals for our various Agilent VNAs they indicate that when calculating for example S11(mag) uncertainty there are terms in the Stability for S21 and S12. Hope someone may be able to help... |
对于sinlge端口的情况,设置S12 = S21 = 0(表示-infintie dB或没有从端口1到端口2的连接)。
那么它将是单端口不确定性,顺便说一下这是电子表格的默认值。否则来自端口2的负载匹配将影响S11不确定性。 使用“设置图表参数”更改DUT S参数的值。 它们确实影响了不确定性。 以上来自于谷歌翻译 以下为原文 For the case of sinlge port, set S12=S21=0 (means -infintie dB or no connection from port 1 to port 2). Then it will be single port uncertainty, and by the way this is the default of the spread sheet.. Otherwise the load match from port 2 will affect the S11 uncertainty. Use "set chart parameters" to change the values of the DUT S-parameters. They do affect the uncertainty. |
1287 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2064 浏览 5 评论
2951 浏览 3 评论
1111浏览 1评论
753浏览 0评论
926浏览 0评论
1287浏览 0评论
GMT+8, 2024-12-24 00:59 , Processed in 1.468759 second(s), Total 76, Slave 60 queries .
