STM32F072,使用HAL库。按键中断进出STOP模式,不开启WWDG时,一切正常。开启WWDG窗口看门狗,使能中断,正常喂狗可进stop模式。但是从stop模式唤醒后,程序不正常。不知道从stop模式中唤醒后,该怎么操作WWDG。是重新初始化还是只清除计数值,菜鸟求助各位大大,不胜感激
7个回答
看门狗随后要用在073上,同问。
唤醒后优先初始化时钟和总线,然后喂狗,WWDG喂的时候,要注意窗口期,
When CPu wakes up from STOP mode by the WWDG ewi interrupter, why does it cause a system reset quickly ?
How do you slove this problem ? thanks a lot. |
初级少校 发表于 2018-12-29 19:30 when the cup needs the WWDG ewi wakeup , it is already in the edge of the system reset. So i guess it does not work to feed the wwdg before entering stop mode. However , what about feeding the wwdg before quiting the STOP Mode ? |
好好看看手册的
答案这里面的
2272 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2083 浏览 3 评论
4708 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2229 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
2773 浏览 1 评论
GMT+8, 2024-12-27 16:44 , Processed in 0.668100 second(s), Total 50, Slave 45 queries .
