你好,
是否可以确认WiTAP头是否被WICE支持?无线电报定义字段 如果是,有一个文档或文件可以提供定义和可用的列表吗? 无线电报头不是标准的,也可能不可用。我知道这是基于司机和收音机。我认为Broadcom或CyPress可能以某种方式传递信息,只是需要一些确认。 谢谢您! 以上来自于百度翻译 以下为原文 Hello, Is it possible to confirm if the radiotap headers are supported by WICED ? Radiotap - Defined Fields If yes, is there a document or file that would provide a list of the ones that are defined and available? Radiotop headers are not standard and may or may not be available. I understand this is based on the driver as well as the radio. I am thinking Broadcom/Cypress may have carried the information one way or another, just need some confirmation. Thank you! |
8个回答
我可以知道你正在使用的Wi-Fi芯片吗?我只能在/43xxxWi-Fi/Labe/Test/WLSoo/43012C0/Asdio/BCMWiFi/Src/BCMWiFieReavoTop.c中找到关于RooTAP头的信息。请详细说明你的要求。
以上来自于百度翻译 以下为原文 May I know the Wi-Fi chip that you are using? I could only find information on radiotap headers in /43xxx_Wi-Fi/libraries/test/wl_tool/43012C0/shared/bcmwifi/src/bcmwifi_radiotap.c. Also why do you need radiotap headers? Please elaborate your requirement. |
asd013 发表于 2018-12-29 09:58 谢谢你的回复。我没有在5.1 SDK上面提到的路径。43012C0未列出。唯一的文件,我可以找到在无线电龙头是://43xxxWi-Fi/WICES/Stural/MCU/BCM4390x/外设/包含/PROTO /IEEE80211yRooTop.h 我想在这一点上,我们正在试图解释从收音机里回来的额外数据。还有额外的字节被识别为无线分接头信息,我们正在试图找出它的含义。 我只需要知道上面的文件是否是目前唯一可用的信息。 任何额外的信息都是受欢迎的。 谢谢您! 以上来自于百度翻译 以下为原文 Thanks for the reply. I do not have the path mentioned above in the 5.1 SDK. The 43012C0 is not listed. The only file that I can find on radio tap is under: ./43xxx_Wi-Fi/WICED/platform/MCU/BCM4390x/peripherals/include/proto/ieee80211_radiotap.h I think at this point we are trying to interpret the extra data coming back from the radio. There are extra bytes that have been identified as radio tap information and we are trying to figure out the meaning of it. I just need to know if the file above is the only information available currently on this. Any extra information is welcome. Thank you! |
ncvttwer 发表于 2018-12-29 10:10 Mikelel.Toumi151583636写道: 谢谢你的回复。我没有在5.1 SDK上面提到的路径。 它在SDK-5.2.0中。 以上来自于百度翻译 以下为原文 mickael.toumi_1583836 wrote:It's in SDK-5.2.0. |
ncvttwer 发表于 2018-12-29 10:10 在IEEE80211yReloTop.h中定义了RoopTAP字段。如果使用WICD SDK 6,则在Lab\TestWLLoo\43012C0BaseBCMWiFiSrcBCMWiFiLeavoTop.c中定义了用于解析的函数。 以上来自于百度翻译 以下为原文 The radiotap fields are defined in ieee80211_radiotap.h. If you are using WICED SDK 6.0, there are functions defined in librariestestwl_tool43012C0sharedbcmwifisrcbcmwifi_radiotap.c for parsing. |
H-GRSR 该文件在最新SDK(见图片)中不可用。我也在整个文件夹中搜索了BCMWiFiReaToop.c。找不到它(见图片)。从文件夹中删除43012C0。 我仍然可以在//WICES/Stural/MCU/BCM4390X/外围设备/包括/PROTO /IEEE80211yRooTop.h中找到头文件。 你能给我发送这个BCMWiFiReaToop.c文件吗? 以上来自于百度翻译 以下为原文 Hi grsr The file is not available in the latest SDK (see picture). I also ran a search on the whole folder for the bcmwifi_radiotap.c it is nowhere to be found (see picture). The 43012C0 is removed from the folder. I still can find the header file in: /WICED/platform/MCU/BCM4390x/peripherals/include/proto/ieee80211_radiotap.h Would you be able to send me this bcmwifi_radiotap.c file? |
GRSR 您的初始语句似乎假设用户拥有SDK的早期采纳版本,因为在今天的广阔市场中不支持43012。 以上来自于百度翻译 以下为原文 grsr Your initial statement appears to assume the user has the Early Adopter version of the SDK as the 43012 is not supported in the broad market today. |
我检查了Wiice Studio 6,它是社区可用的,并且发现无线地址头的信息只存在于WICRStaleMCUBCM4390xEdvurals\Pro to IEEE80211yReavoTop.h。我以前检查过的WSDE SDK版本不适用于广阔的市场。 以上来自于百度翻译 以下为原文 I checked WICED Studio 6.0 which is available to the community and found that the information for radiotap headers is only found in WICEDplatformMCUBCM4390xperipheralsincludeprotoieee80211_radiotap.h. The WICED SDK version in which I checked previously is not available to the broad market. |
MIFO写道: GRSR 您的初始语句似乎假设用户拥有SDK的早期采纳版本,因为在今天的广阔市场中不支持43012。 实际上,库/测试/WLIOrg/43012C0/Boo/BCMWiFi/SrC/BCMWiFiFieloTop.c 在SDK-5.2(正如我在前一篇文章中提到的)。 不知怎么说,SDK-06. 以上来自于百度翻译 以下为原文 mifo wrote:Actually, the libraries/test/wl_tool/43012C0/shared/bcmwifi/src/bcmwifi_radiotap.c is in sdk-5.2 (As I mentined in previous post). Somehow, it's no longer exist in sdk-6.0.x. |
740个成员聚集在这个小组
加入小组1981 浏览 1 评论
1743 浏览 1 评论
3518 浏览 1 评论
1673 浏览 6 评论
1450 浏览 1 评论
228浏览 2评论
135浏览 2评论
328浏览 2评论
275浏览 2评论
459浏览 2评论
GMT+8, 2024-8-24 23:30 , Processed in 0.958509 second(s), Total 90, Slave 74 queries .
