扫一扫,分享给好友
你好,
请告诉我CY7C6213驱动程序是否支持Windows 10。 在数据表中,支持窗口10。但是,当我检查下一个站点的驱动程序时,它似乎还没有对应。 HTTP://www. CyPress 最好的问候, 以上来自于百度翻译 以下为原文 Hello, Could you please tell me whether CY7C65213 driver supports Windows 10. In the data sheet, Window 10 is supported. However, when I check the driver at the following site, it seems that it does not correspond yet. http://www.cypress.com/documentation/other-resources/u***-serial-drivers Best Regards, |
6个回答
你好,斯里纳斯 谢谢你的快速反应。 您能告诉我们与Windows 10 IOT兼容的CyPress系列驱动程序的发布时间表吗? (我们的一个客户要求这个) 最好的问候, 以上来自于百度翻译 以下为原文 Hello Srinath S, Thank you for quick response. Could you inform us the release schedule of CypressSerial driver which is compatible with Windows 10 IoT ? (One of our customer is asking for this) Best Regards, |
你好, 开发工作正在进行,但司机发布的确切时间表尚未确定。请放心,它将最早更新。 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello, Development works are on but the exact schedule of driver release is not yet confirmed. Please be assured that it will be updated at the earliest. Best regards, Srinath S |
你好, 请告诉我与Windows 10 IOT企业兼容的驱动程序的状态。 最好的问候, 以上来自于百度翻译 以下为原文 Hello, Please tell me the status about the driver compatible with Windows 10 IoT Enterpris. Best Regards, |
你好,Hitoshi Kumada san, 请参考下面的FX3SDK链接。在安装该软件包时,可以在以下路径中找到驱动程序。 C:程序文件(x86)CyPress EZ-USB FX3 SDK 1.3驱动程序 HTTP://www. CyPress .COM/DCOMPANTION/SCADVIEWS/EZ-UB-FX3软件开发包 对于CyPress USB串行驱动程序,从Windows更新中获取驱动程序。 此外,必须注意的是,这些驱动程序支持到Win 10 RS3和仅X86和X64架构。ARM ISA不受这些驱动程序的支持。 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Hitoshi Kumada-san, Please refer to the below link for the FX3 SDK. Upon installation of the package, the drivers can be found in the following path. C:Program Files (x86)CypressEZ-USB FX3 SDK1.3driver http://www.cypress.com/documentation/software-and-drivers/ez-u***-fx3-software-development-kit For Cypress USB Serial driver, the drivers are fetched from the Windows Update. Also, it has to be noted that these drivers support till Win 10 RS3 and only x86 and x64 architectures. ARM ISA is not supported by these drivers. Best regards, Srinath S |
wangcong12138 发表于 2018-12-29 21:07 你好,斯里纳斯S,Kumada san 谢谢你提供的信息。 我下载了这个路径,并确认了“CyPress CyUSB 3.SIS程序员的参考”。 但我找不到支持OS Windows 10 IoT的描述。 这可以用作CY7C6213的Windows 10 IOT的驱动程序吗? 最好的问候, 以上来自于百度翻译 以下为原文 Hello Srinath S, Kumada-san Thank you for the information. I downloaded that path, and confirmed 'Cypress CyU*** 3.sys Programmer's Reference'. but I could not find description of support OS 'Windows 10 IoT'. Can this be used as a driver for Windows 10 Iot of CY7C65213 ? Best regards, |
你好,Haruhiko Shimoda, Windows 10驱动程序适用于Windows 10的IOT,只要体系结构是X64或X86,可以用于CY7C6213。 最好的问候,Srinath S 以上来自于百度翻译 以下为原文 Hello Haruhiko Shimoda-san, Windows 10 drivers are suitable for Windows 10 IoT as long as the architecture is x64 or x86 and can be used for CY7C65213. Best regards, Srinath S |
757个成员聚集在这个小组
加入小组2134 浏览 1 评论
1874 浏览 1 评论
3697 浏览 1 评论
1810 浏览 6 评论
1557 浏览 1 评论
753浏览 2评论
506浏览 2评论
466浏览 2评论
418浏览 2评论
1109浏览 2评论
GMT+8, 2025-2-1 04:57 , Processed in 0.897061 second(s), Total 53, Slave 48 queries .
