扫一扫,分享给好友
你好
我正在使用VIVADO的30天免费试用版,我无法运行KC705评估套件的实施: [Common 17-345]找不到功能'Synthesis'和/或设备'xc7k325t'的有效许可证。 请运行Vivado许可证管理器以获取有关确定哪些功能和设备已获得系统许可的帮助。解决方案:在Vivado许可证管理器中检查许可证的状态。 对于调试帮助,请搜索Xilinx支持“许可常见问题解答”。 如果您使用的是许可证服务器,请验证许可证服务器是否已启动并运行与您正在使用的Xilinx软件版本兼容的xilinx守护程序版本。 请注意,Vivado 2017.3及更高版本需要将许可证服务器工具升级到Flex 11.14.1工具。 请与您的许可证管理员确认已安装正确版本的许可证服务器工具。 支付的VIVADO软件是否包含设备xc7k325t的许可证? 谢谢 以上来自于谷歌翻译 以下为原文 Hello I am using a 30 day free trial of VIVADO and i can't run the implementation for the KC705 evaluation kit: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7k325t'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". If you are using a license server, verify that the license server is up and running a version of the xilinx daemon that is compatible with the version of Xilinx software that you are using. Please note that Vivado 2017.3 and later requires upgrading your license server tools to the Flex 11.14.1 tools. Please confirm with your license admin that the correct version of the license server tools are installed. Is the paying VIVADO software includes the license of device xc7k325t? Thank you |
15个回答
你好@谋杀绿脚趾,
请在上面的屏幕截图中选择#3。 这就是你需要的。 最后一个是与Vivado HLS工具相关的评估许可证,而不是Vivado评估许可证。 因此,只需获得#3。 在您的情况下,不需要其余许可证。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @lebowski, Please select #3 in your screenshot above. This is what you need. The last one is a Vivado HLS tool related evaluation license and not the Vivado one. Therefore, just obtain #3. The rest of the licenses are not needed in your case. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
如果您支付Vivado许可证,那么您将能够围绕xc7k325t构建项目。 但是,您似乎正在尝试使用Vivado的30天试用版,这也应该允许您围绕xc7k325t构建项目。 要使用Vivado的30天免费试用版,首先需要下载并安装Vivado。 然后,转到主页>支持> Product_Licensing,系统将要求您登录Xilinx帐户。 然后,单击“Vivado Design Suite(无ISE):30天评估许可证”以获得免费试用许可证。 以上来自于谷歌翻译 以下为原文 Is the paying VIVADO software includes the license of device xc7k325t? If you pay for a Vivado license then you will be able to build projects around the xc7k325t. However, it seems you are trying to use the 30-day trial of Vivado, which should also allow you to build projects around the xc7k325t. In order to use the 30 day free trial of Vivado, you first need to download and install Vivado. Then, go to the Home>Support>Product_Licensing |
你好,
我已经下载了VIVADO,我已经获得了我的免费许可证。 我一直在围绕其他设备构建项目,合成和实现工作正常,但对于这个特定设备,我在tcl控制台中有vivado的无效许可证消息 以上来自于谷歌翻译 以下为原文 Hello, I allready downloaded VIVADO and i have allready my free license. I have been building projects around other devices, the synthesis and implementation worked, but for this particular device i have the invalid license message by vivado in the tcl console |
你好@谋杀绿脚趾,
首先,您能否确认您是使用试用许可证还是30天评估许可证,因为它们有所不同? 30天试用许可证允许您定位每个Xilinx器件并运行所有Xilinx应用程序(比特流生成除外)。 30天试用许可证自生成之日起30天后到期。 30天的评估许可证允许您定位每个Xilinx器件并运行所有Xilinx应用程序(包括比特流生成)。 30天评估许可证自生成之日起30天后到期.30天评估许可证是节点锁定许可证。 您还说过:“我一直在围绕其他设备构建项目” 对我来说,它看起来像“其他设备”是Vivado WebPACK支持的设备,您不需要任何其他许可证,这就是为什么您没有看到针对这些特定设备的任何许可问题。 现在,对我来说,我不明白为什么你甚至需要使用任何试用版或eval许可证? 如果您购买了Kintex 7 FPGA KC705评估套件,该套件随附免费的“节点锁定和设备锁定至Kintex-7 XC7K325T FPGA,具有1年更新”许可文件(作为套件中的凭证), 从这个链接可以看出: https://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html#toolsip 因此,您能否确认您是否已兑换此优惠券?如果没有,请在套件中找到此优惠券然后兑换,这将解决您的许可问题。 希望这可以帮助。 如果您对我有任何疑问,请告诉我。 祝你今天愉快。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @lebowski, First of all, can you please confirm if you are using a trial license or a 30-day Evaluation license, as these are different? A 30-day trial license allows you to target every Xilinx device and run all Xilinx applications (with exception of bitstream generation). The 30-day trial license expires 30 days from the date it is generated. A 30-day evaluation license allows you to target every Xilinx device and run all Xilinx applications (including bitstream generation).
You have also stated this: "I have been building projects around other devices" To me, it looks like these "other devices" are the Vivado WebPACK supported devices, for which you don't need any additional licenses and that is the reason why you haven't seen any licensing issues targeting these specific devices. Now, to me, i don't understand why you even need to use any trial or eval licenses? If you have purchased Kintex 7 FPGA KC705 Evaluation Kit, this kit comes with a free "Node locked & Device-locked to the Kintex-7 XC7K325T FPGA, with 1 year of updates" license file (comes as a voucher in the kit), as can be seen from this link: https://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html#toolsip Therefore, can you please confirm if you have redeemed this voucher yet or not? If not, then please find this voucher in the kit and redeem it then and this will solve your licensing issue then. Hope this helps. If you have any questions for me, please let me know. Have a nice day. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
我还没有购买FPGA,我想在购买之前模拟它。
我想我正在使用30天的评估许可证,但我不知道我在哪里可以查看? 如果XC7K325T不在webpack支持的设备中,我该怎么做才能模拟XC7K325T 以上来自于谷歌翻译 以下为原文 I haven't bought the FPGA allready, i want to simulate it before i buy it. I think i am using the 30-day Evaluation license but i'm not sure where can i check that? What can i do to be able to simulate the XC7K325T if it is not in the webpack supported devices |
不,对不起,我想我有30天的试用许可证
以上来自于谷歌翻译 以下为原文 No sorry i think i have the 30 day trial licence |
你好@谋杀绿脚趾,
在这种情况下,30天的评估许可证将适用于您。 您是否已从www.xilinx.com/getlicenses页面生成此许可证? 请登录,然后查看此许可证是否仍列在“创建的新许可证”选项卡下。 如果是这样,您还没有生成此许可证。 如果您没有看到列出的内容,那么您很可能已经生成了此许可证,这将列在“管理许可证”选项卡下。 此外,如果您打开Vivado许可证管理器,您是否在表格中看到此许可证? 例如。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @lebowski, 30-day Evaluation license will work for you in this situation. Have you generated this license from www.xilinx.com/getlicenses page yet? Please log in and then see if this license is still listed under the Created New Licenses tab. If so, you haven't generate this license yet. If you don't see this listed, then you most likely have already generated this license and this would be listed under the Manage Licenses tab. Also, if you open your Vivado License Manager, do you see this license in the table? E.g. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
不,我没有在XILINX上生成许可证。
这就是vivado许可证管理器上的内容 以上来自于谷歌翻译 以下为原文 No i haven't generated the license on XILINX. This is what is see on the vivado license manager |
嗨再次@ lebowski,
如您所见,没有列出许可证,这意味着您没有有效的许可证。 因此,请按照我之前的帖子中的说明登录Xilinx产品许可页面,获取并安装30天的Eval许可证。 完成后,您的许可问题将被分类(好吧,无论如何都是30天)。 希望这可以帮助 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hi again @lebowski, As you can see, no licenses listed, that means you don't have a valid license for this. Therefore, please log in to the Xilinx Product Licensing page as indicated in my previous post and obtain and install your 30-days Eval license. Once done, your licensing issue will be sorted then (well, for 30-day in anyway). Hope this helps Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
@lebowski,
您可以单击获取免费Vivado或IP评估许可证选项,或者只需访问www.xilinx.com/getlicenses,这将重定向您进入Xilinx产品许可页面,您可以在其中选择并生成Vivado 30 -days评估许可证。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @lebowski, You can either click on Get free Vivado or IP Evaluation license option or just go to www.xilinx.com/getlicenses and this will re-direct you to the Xilinx Product Licensing page, where you would be able to select and generate your Vivado 30-days Evaluation license. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
我应该检查所有这些还是只检查最后一个?
以上来自于谷歌翻译 以下为原文 Should i check all of them or only the last one? |
你好@谋杀绿脚趾,
请在上面的屏幕截图中选择#3。 这就是你需要的。 最后一个是与Vivado HLS工具相关的评估许可证,而不是Vivado评估许可证。 因此,只需获得#3。 在您的情况下,不需要其余许可证。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @lebowski, Please select #3 in your screenshot above. This is what you need. The last one is a Vivado HLS tool related evaluation license and not the Vivado one. Therefore, just obtain #3. The rest of the licenses are not needed in your case. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好再次@ lebowski,
非常感谢让我们知道并且我们现在已经解决了您的问题。 在您的问题得到解决后,请将适当的回复标记为已接受的解决方案(有关详细信息,请访问此处:https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions) ,那么话题就可以完成了。 感谢您的帮助。 提前谢谢,祝你有个美好的一天。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello again @lebowski, Thanks a lot for letting us know and I'm glad to see your issue is resolved now. As your issue is solved, please mark an appropriate response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so the topic can be completed then. We appreciate your help. Thanks in advance and have a great day. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2363 浏览 7 评论
2782 浏览 4 评论
2248 浏览 9 评论
3326 浏览 0 评论
2414 浏览 15 评论
735浏览 1评论
525浏览 1评论
338浏览 1评论
743浏览 0评论
1941浏览 0评论
GMT+8, 2024-11-10 17:08 , Processed in 1.217219 second(s), Total 72, Slave 67 queries .
