你好,
我已经阅读了AR#62380,但仍无法找到我的问题的解决方案。 我在一个生产车间工作,这台机器已经回到Windows 95,我们已经升级了多年。 我们最近尝试使用ISE 14.7安装Windows 10。 即使在尝试AR#62380中所述的内容之后,我们仍然无法将JTAG编程连接起来。 它在Windows 7中运行良好。我们的生产车间如何支持JTAG的发展? 例如, iMPACT-64位与现有的BSDL文件,它只是崩溃了! 还有其他例子。 谢谢您的考虑! 以上来自于谷歌翻译 以下为原文 Hello, I have read AR #62380, but still cannot find the solution to my problem. I work in a manufacturing floor that has had machines going back to Windows 95, that we have upgraded over the years. We recently tried to install Windows 10 with ISE 14.7. Even after trying what is stated in AR#62380, we still cannot get the JTAG programming to connect. It works fine in Windows 7. How is our manufacturing floor going to support JTAG going forward? For example, iMPACT-64 bit with an existing BSDL file and it just crashes out! There are other examples as well. Thank you for your consideration! |
您好bryan_lewis@selinc.com,
Xilinx不正式支持在ISE Design Suite中使用Windows 8.1或Windows 10。 AR是您可以根据使用它们解决的一些问题尝试的最佳解决方法的混合。 考虑到您已经尝试了所有这些,最好的方法是使用此处列出的操作系统,然后继续调试其中的崩溃问题。 否则继续使用已经适用于你的Win7。 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 适当的帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。给予您认为有用且回复导向的帖子。感谢.---------------- -------------------------------------------------- ----------------------------- 以上来自于谷歌翻译 以下为原文 Hi bryan_lewis@selinc.com, Xilinx does not officially support using Windows 8.1 or Windows 10 with ISE Design Suite. The AR is a mix of best workarounds you can try based on some issues which have been resolved using them. Considering you have tried all of them, the best way out of this is to use OS listed here and then continue debug on crash issues in them. Else proceed with Win7 which already works at your end. Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the appropriate post as an answer "Accept as solution" in case it helps to resolve your query. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------- |
Hellobryan_lewis@selinc.com,
这个主题仍然是开放的,等着你。 如果您的问题已得到解答和/或您的问题已得到解决,请将已解决的问题标记为已接受的解决方案(有关详细信息,请访问此处:https://forums.xilinx.com/t5/help/faqpage/faq-category -id /解决方案#)。 这样,主题即可完成。 如果没有解决/回答,请回复主题。 提前谢谢,祝你有个美好的一天。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello bryan_lewis@selinc.com, This topic is still open and is waiting for you. If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then. If this is not solved/answered, please reply in the thread. Thanks in advance and have a great day. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1797浏览 1评论
624浏览 1评论
486浏览 1评论
2037浏览 0评论
763浏览 0评论
GMT+8, 2025-1-14 08:27 , Processed in 1.288659 second(s), Total 77, Slave 61 queries .
