尝试使用vivado .lic文件进行编译时,我收到许可错误。
我看到有关在ISE上使用vivado设计套件版本的相互矛盾的信息。 我有一个涉及斯巴达6芯片的项目。 我购买了许可证,但似乎没有与ISE合作。 是否可以将购买的vivado文件与ISE 14.7一起使用? 以上来自于谷歌翻译 以下为原文 I'm getting licensing errors when trying to compile using the vivado .lic file. I'm seeing conflicting information regarding the use of vivado design suite edition on ISE. I have a project that involves spartan 6 chips. I purchased the license but it doesn't seem to be working with ISE. Is it possible to use the purchased vivado file with ISE 14.7? |
6个回答
你好@ tsensel,
请注意,现在,如果您购买了Vivado许可证,ISE(相同版本的许可证)将自动添加到您的帐户中。 但是,在您的情况下,似乎没有添加所需的ISE许可证(不知何故),在这种情况下,您需要联系Xilinx客户服务团队(根据许可证或订单开设新的电子履行SR) 使用Xilinx在线服务门户网站:https://www.xilinx.com/support.html#serviceportal)他们会帮助您完成此操作,并将所需的许可证添加到您的Xilinx许可帐户。 无论如何,我很高兴你的问题现在已经排序,你已经设法获得所需的(缺失的)ISE许可证。 对由此造成的任何不便表示歉意。 祝你今天愉快。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @tsensel, Please note that these days, if you'd purchase a Vivado license, ISE (the same edition license) will/should be automatically added to your account. However, it looks like in your case, the required ISE license wasn't added (somehow) and indeed, in this case, you'd need to contact Xilinx Customer Services team (by opening a new electronic fulfillment SR under the LICENSING or ORDER section using Xilinx online Service Portal: https://www.xilinx.com/support.html#serviceportal) and they'd help you on this and will add the required license to your Xilinx Licensing account. Anyhow, i'm glad your issue is now sorted and you've managed to obtain the required (missing) ISE license. Apologies for any inconvenience caused. Have a nice day. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
你好@ tsensel
你能在这里分享许可文件吗? 还在Vivado中输出以下tcl命令:report_environment -file env.txt 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @tsensel Can you share the license file here? Also output of following tcl command in Vivado: report_environment -file env.txt Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我还在安装vivado。
是不是可以使用独立的ISE 14.7? Xilinx.lic 2 KB 以上来自于谷歌翻译 以下为原文 I'm still installing vivado. Is it not possible to use the stand alone ISE 14.7? Xilinx.lic 2 KB |
你好@ tsensel
您附加的许可证文件仅具有Vivado功能。 请登录Xilinx许可站点并生成ISE许可证(按照您生成Vivado许可证所遵循的相同步骤)。 您可以在不安装Vivado的情况下使用ISE 14.7。 如果您的帐户中没有ISE许可,请在此处提出SR。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @tsensel The license file you attached has only Vivado features. Please login Xilinx Licensing Site and generate ISE License (follow the same steps that you followed to generate Vivado license). You can use ISE 14.7 without installing Vivado. If the ISE license is not available in your account, please raise a SR here. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我必须联系支持并请求访问ISE。
他们发布了针对ISE的新许可证。 一切都运作正常。 如果您购买了vivado以使用ISE,则必须联系支持部门并要求将ISE许可证发放到您的帐户。 以上来自于谷歌翻译 以下为原文 I had to contact support and request access for ISE. They issued a new license specific for ISE. Everything is functioning correctly. If you bought vivado to use ISE, you must contact support and request the license for ISE be issued to your account. |
你好@ tsensel,
请注意,现在,如果您购买了Vivado许可证,ISE(相同版本的许可证)将自动添加到您的帐户中。 但是,在您的情况下,似乎没有添加所需的ISE许可证(不知何故),在这种情况下,您需要联系Xilinx客户服务团队(根据许可证或订单开设新的电子履行SR) 使用Xilinx在线服务门户网站:https://www.xilinx.com/support.html#serviceportal)他们会帮助您完成此操作,并将所需的许可证添加到您的Xilinx许可帐户。 无论如何,我很高兴你的问题现在已经排序,你已经设法获得所需的(缺失的)ISE许可证。 对由此造成的任何不便表示歉意。 祝你今天愉快。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @tsensel, Please note that these days, if you'd purchase a Vivado license, ISE (the same edition license) will/should be automatically added to your account. However, it looks like in your case, the required ISE license wasn't added (somehow) and indeed, in this case, you'd need to contact Xilinx Customer Services team (by opening a new electronic fulfillment SR under the LICENSING or ORDER section using Xilinx online Service Portal: https://www.xilinx.com/support.html#serviceportal) and they'd help you on this and will add the required license to your Xilinx Licensing account. Anyhow, i'm glad your issue is now sorted and you've managed to obtain the required (missing) ISE license. Apologies for any inconvenience caused. Have a nice day. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2308 浏览 7 评论
2719 浏览 4 评论
2203 浏览 9 评论
3282 浏览 0 评论
2355 浏览 15 评论
633浏览 1评论
1685浏览 1评论
444浏览 1评论
203浏览 1评论
653浏览 0评论
GMT+8, 2024-9-22 09:49 , Processed in 1.315906 second(s), Total 56, Slave 50 queries .
