扫一扫,分享给好友
大家好
我可以在matlabwith Vivado上安装Xilinxsystem生成器吗? 有了ISE,有一个应用程序调用System Generator Matlab Configuration,但现在有了Vivado,我没有看到这样的应用程序 我希望Xilinx不要像许多其他应用程序那样放弃这个应用程序 以上来自于谷歌翻译 以下为原文 Hello everyone Can I Install Xilinx system generator on Matlab with Vivado With ISE there is an application call System Generator Matlab Configuration, but now with Vivado I don't see such application I hope Xilinx don't give up this application also like many other applications |
4个回答
谢谢您的回复
系统生成器仅在安装Vivado系统版本时可用,因此在我第一次安装Vivado设计套件时,此选项未出现。 这是我的错误,为什么系统生成器没有安装在Matlab中。 再次感谢你 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Thank you for your reply The system generator is available during installing the Vivado system edition only, so when at first time when I install the Vivado design suite this option didn't appear. and that is my wrong and that why system generator not installed in Matlab. Thank you again View solution in original post |
@bamerni,
是的,在Vivado安装期间提供了选择MATLAB可执行文件的选项。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @bamerni, Yes, the option to select the MATLAB executable is given during Vivado installation. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
你好
安装系统生成器后,您可以从开始菜单中找到matlab配置器,如下面的快照所示。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Once you install the system generator you can find the matlab configurator from the start menu as shown in the snapshot below. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
谢谢您的回复
系统生成器仅在安装Vivado系统版本时可用,因此在我第一次安装Vivado设计套件时,此选项未出现。 这是我的错误,为什么系统生成器没有安装在Matlab中。 再次感谢你 以上来自于谷歌翻译 以下为原文 Thank you for your reply The system generator is available during installing the Vivado system edition only, so when at first time when I install the Vivado design suite this option didn't appear. and that is my wrong and that why system generator not installed in Matlab. Thank you again |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1171浏览 1评论
585浏览 1评论
451浏览 1评论
2005浏览 0评论
729浏览 0评论
GMT+8, 2024-12-23 15:38 , Processed in 1.378523 second(s), Total 82, Slave 66 queries .
