我将flexera许可证工具下载到我的服务器以配置许可证管理器。
在此过程中,我必须浏览到lmgrd,许可证文件和日志文件。 我没有在安装中看到任何要浏览的日志文件。 我该如何处理这种情况? 以上来自于谷歌翻译 以下为原文 I downloaded the flexera license tools to my server in order to configure the license manager. In this process, I had to browse to the lmgrd, license file and log file. I don't see any logfile in the installation to browse to. How do I manage this situation? |
嗨@ fairleighdickinson,
lmgrd -c Xilinx.lic -l debug.log 这将在同一文件夹中生成debug.log。 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉------------------------- -------------------------------------------------- -------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @fairleighdickinson, lmgrd -c Xilinx.lic -l debug.log This will generate the debug.log in the same folder. Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- View solution in original post |
lmgrd -c Xilinx.lic -l debug.log 这将在同一文件夹中生成debug.log。 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉------------------------- -------------------------------------------------- -------------------- 以上来自于谷歌翻译 以下为原文 Hi @fairleighdickinson, lmgrd -c Xilinx.lic -l debug.log This will generate the debug.log in the same folder. Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2441浏览 1评论
658浏览 1评论
519浏览 1评论
2074浏览 0评论
800浏览 0评论
GMT+8, 2025-2-23 19:05 , Processed in 1.219769 second(s), Total 78, Slave 62 queries .
