扫一扫,分享给好友
您好,我想下载Xilinx Vivado 2017.1但是,每次我收到以下错误:“由于您的帐户导出合规性验证失败,我们无法满足您的要求。”
谁能帮我? 提前致谢 以上来自于谷歌翻译 以下为原文 Hello, I wanna download Xilinx Vivado 2017.1 But, every time I got the following error: "We cannot fulfill your request as your account has failed export compliance verification." Can anyone help me? Thanks in advance |
3个回答
两个常见的问题:
(1)你住在哪里? Xilinx不允许将其软件导出到某些国家/地区。 (2)您的个人资料中的所有信息(姓名,地址等)是否已填写? 以上来自于谷歌翻译 以下为原文 The two usual questions: (1) Where do you live? Xilinx isn't allowed to export their software to some countries. (2) Is all the information in your profile (name, address, etc) filled in? |
你好@ abdellah_titech
为Vivado 2017.1提出下载变通方法请求 在此处提出出口合规性问题的服务请求。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @abdellah_titech Raise a download workaround request here for Vivado 2017.1 Raise a service request for export compliance issue here. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2439 浏览 7 评论
2834 浏览 4 评论
2306 浏览 9 评论
3387 浏览 0 评论
2482 浏览 15 评论
1669浏览 1评论
613浏览 1评论
477浏览 1评论
2027浏览 0评论
754浏览 0评论
GMT+8, 2025-1-9 05:09 , Processed in 1.172531 second(s), Total 79, Slave 63 queries .
