扫一扫,分享给好友
亲爱的柏树,
在哪里可以找到CYW43907的参考手册和程序指南? 谢谢! 以上来自于百度翻译 以下为原文 Dear Cypress, Where I can find the reference manual and programming guide for CYW43907? Thanks! |
9个回答
嗨,伊凡,
我们只是(内部)讨论了43907个程序员指南的公共可用性,并注册地图/定义。MICO-KAVS GRSR VIKR UTSV RICA。我已经向你的请求添加了他们的官方答复。 以上来自于百度翻译 以下为原文 Hi Ivan, We were just (internally) discussing the public availability of the 43907 Programmers Guide, and Register Map/Definitions. mifo kavs grsr vikr utsv rica. I've added the team to your request for their official reply. |
nmmmma 发表于 2018-12-26 19:18 在这一点上,我们不打算让程序员的指南提供给公众。如果位置改变,我们会通知你。 请向您的本地CY团队提供任何问题或关注, 以上来自于百度翻译 以下为原文 At this point, we are not planning on making the Programmer's Guide available to the public. We will let you know if that position changes. Please reach out to your local CY team with any questions or concerns, |
如果有任何说明: - WiFixNvRMyIMAIL H的缩写词,用于评估板CYW943907AEV1F? -天线分集控制引脚A21,A25。是否有可能将状态从固件上即时更改,或者固定在编译上 -我在哪里可以找到DMA和USB子系统的例子? 以上来自于百度翻译 以下为原文 If there any description for: -acronyms in wifi_nvram_image.h for Evaluation Board CYW943907AEVAL1F? -antenna diversity control pins A21, A25. Is it possible to change state from firmware on-the-fly or it is fixed on compilation -where I can find examples for DMA and USB subsystems? |
对于WiFixNvRMIGIMAGE图像中的首字母缩写词,请参阅AN214841-HTTP://wwwyCysP.COM/FIL/9828下载 以上来自于百度翻译 以下为原文 for acronyms in wifi_nvram_image.h please refer to AN214841- http://www.cypress.com/file/298281/download |
谢谢链接,但是在给定的AN214841中没有关于大量配置参数的信息,例如: “SWDIVIGEN=1”“x00” “SWDIVIGGPIO=0”“x00” “SWDIVIOSSWCTRLGEN=2”“x00” “SWDIVIVSWCTRLANT0=0”“x00” “SWDIVIVSWCTRLYANT1=1”“x00” “Rx链=1”“x00” “TxCar=1”“x00” 请提供更多关于WiFixNvRAMIX图像值的信息? 谢谢您! 以上来自于百度翻译 以下为原文 Thank you for link, but in given AN214841 there is no information about a big amount of configuration parameters such as: "swdiv_en=1" "x00" "swdiv_gpio=0" "x00" "swdiv_swctrl_en=2" "x00" "swdiv_swctrl_ant0=0" "x00" "swdiv_swctrl_ant1=1" "x00" "rxchain=1" "x00" "txchain=1" "x00" Please provide more informaiton about wifi_nvram_image values? Thank you! |
很抱歉耽搁了这件事。 SWDIVIEN是使软件多样性。 SWDIVIGGPIO用于控制用于控制外部天线开关的GPIO引脚。 SWDIVI SWCCTLLIN是一个分集模式选择条目,CYW43907使用模式2。 您所提到的所有其他选项都是特定的平台(CYW43907),它不需要更改。 以上来自于百度翻译 以下为原文 Sorry for the delay in getting back on this. swdiv_en is to enable Software diversity. swdiv_gpio is for controlling which GPIO pin to use for controlling external antenna switch. swdiv_swctrl_en is a diversity mode selection entry, CYW43907 is using mode 2. All other options that you have mentioned are more of platform (CYW43907) specific which need not be changed. |
请寄给我USB外围设备的例子 以上来自于百度翻译 以下为原文 Please send me examples for USB peripheral |
我真心希望你的职位在分配程序员的时候发生变化。 参考文献。村田LBWA1UZ1GC使用43907,我们正在使用。 这个模块在一个新产品中。不得不猜测GPIOs和 函数复用和捆绑的含义很可能是浪费的。 大量的开发工作,转化为大量的努力。 更长的上市时间。这意味着你的零件销量会减少。 以上来自于百度翻译 以下为原文 I truly hope that your position changes on distributing the programmer's reference. The Murata LBWA1UZ1GC uses the 43907, and we're using this module in a new product. Having to guess how the GPIOs and function multiplexing and strapping implications are is very likely to waste an immense amount of development effort, which translates to a much longer time to market. THAT translates to fewer sales of your parts. |
60user142 发表于 2018-12-26 20:53 尼尔赛25954 我们正在研究一个我们称之为“产品指南”的文档,它将解决许多问题。我希望这个产品指南本月准备好。同时,请在GPIOs、函数复用和捆绑暗示方面创建一个新的线程,L1应用程序团队将追踪答案。 以上来自于百度翻译 以下为原文 nyles_2595461 We are working on a document we are referring to as a "product guide" which will address many of these questions. I expect that the product guide will be ready this month. In the meantime, please create a new thread with your specific questions on GPIOs, function multiplexing and strapping implications, and the L1 Apps team will track down answers. |
762个成员聚集在这个小组
加入小组2185 浏览 1 评论
1934 浏览 1 评论
3754 浏览 1 评论
1857 浏览 6 评论
1600 浏览 1 评论
994浏览 2评论
665浏览 2评论
511浏览 2评论
479浏览 2评论
1351浏览 2评论
GMT+8, 2025-4-6 16:38 , Processed in 1.259165 second(s), Total 91, Slave 75 queries .
