扫一扫,分享给好友
我正在尝试登录申请许可证,但不能。
我收到以下消息“我们无法满足您的请求,因为您的帐户导出合规性验证失败。请访问http://www.xilinx.com/support/answers/44043.html以获取解决此错误的可能解决方案。 点击“确定”返回主页。“ 请帮忙。 谢谢, 尼扎尔 以上来自于谷歌翻译 以下为原文 I'm trying to login to claim license voucher but cant. I'm getting the following message "We cannot fulfill your request as your account has failed export compliance verification. Please visit http://www.xilinx.com/support/answers/44043.html for a possible solution to resolve this error. Click 'OK' to return to home page." Please help. Thanks, Nizar |
3个回答
尼扎尔,
现在看着它。 应该很快解决。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Nizar, Looking at it now. Should be resolved shortly. Austin Lesea Principal Engineer Xilinx San Jose |
嗨,您一直在尝试从不受支持的类别D国家访问该网站,因此不允许访问。
以上来自于谷歌翻译 以下为原文 Hi, you've been trying to access the site from an unsupported category D Country therefore access is not permitted. |
你好
请参考类似的主题,希望他们可以帮助您解决问题: https://forums.xilinx.com/t5/Welcome-Join/Export-compliance-verification-error/td-p/717824 https://forums.xilinx.com/t5/Welcome-Join/Failed-export-compliance-verification/td-p/667178 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Please refer the similar threads, hope they may help you with the resolution: https://forums.xilinx.com/t5/Welcome-Join/Export-compliance-verification-error/td-p/717824 https://forums.xilinx.com/t5/Welcome-Join/Failed-export-compliance-verification/td-p/667178 Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
2509 浏览 7 评论
2879 浏览 4 评论
2336 浏览 9 评论
3429 浏览 0 评论
2515 浏览 15 评论
2605浏览 1评论
668浏览 1评论
533浏览 1评论
818浏览 0评论
GMT+8, 2025-3-5 05:38 , Processed in 1.209190 second(s), Total 45, Slave 40 queries .
