我有兴趣购买TEMACIP Core的SITE许可证。
我对Node-Locked vs Floating许可证的工作方式感到困惑。 让我们说有7个团队在项目的不同部分工作,其中大多数人需要能够在给定时间内构建整个项目,尽管其中只有3个实际上可以在不同的TDAC接口上工作,可能不会同时工作。 SITE许可是否意味着在给定位置(以及5英里半径范围内)内的所有用户可以在必要时同时提取许可证? 我们公司实际上只有一个物理位置,所有工程师都在这里工作,所以5英里半径是无关紧要的。 如果我们选择将TEMAC SITE许可证作为浮动许可证,那么每个用户是否能够同时从我们的服务器获取许可证? 如果我们选择使节点锁定的TEMAC SITE许可证,我们是否可以为我们所在位置的每个用户生成单独的节点锁定许可证? 我想我对TEMAC PROJ许可证的多个用户会有同样的问题。我的理解是PROJ许可证只能用于单个项目,但我会假设多个用户可以使用单个许可证 购买许可证的同一个项目。 以上来自于谷歌翻译 以下为原文 I am interested in purchasing a SITE license of the TEMAC IP Core. I am confused about how Node-Locked vs Floating licenses would work. Let's say that there is a team of 7 working on different parts of a project, most of whom need to be able to build the entire project at a given time, though only 3 of them will actually work on different TEMAC interfaces, likely not at the same time. Does a SITE license imply that all users at a given location (and within a 5 mile radius) can pull the license at the same time if necessary? Our company actually only has one physical location, where all the engineers work, so the 5-mile radius is irrelevant. If we chose to make the TEMAC SITE license a floating license, would every user be able to pull a license from our server at the same time? If instead we chose to make the TEMAC SITE license node-locked, could we generate a separate node-locked license for every user at our location? I guess I would have the same questions about multiple users for a TEMAC PROJ license. My understanding is that a PROJ license can only be used on a single project, though I would assume that multiple users could use a single license if they are working on the same project the license was purchased for. |
5个回答
@khal,
是的,SITE和PROJ许可证可以是节点锁定的也可以是浮动的。 SITE许可是否意味着在给定位置(以及5英里半径范围内)内的所有用户可以在必要时同时提取许可证?是 如果我们选择将TEMAC SITE许可证作为浮动许可证,那么每个用户是否能够同时从我们的服务器获取许可证? 是的,可以同时使用许可证的用户数量=购买的座位数量 如果我们选择使节点锁定的TEMAC SITE许可证,我们是否可以为我们所在位置的每个用户生成单独的节点锁定许可证? 是的,那就是你。 您可以选择浮动或节点锁定。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @khal, Yes, the SITE and PROJ licenses can be both node-locked or floating. Does a SITE license imply that all users at a given location (and within a 5 mile radius) can pull the license at the same time if necessary? Yes If we chose to make the TEMAC SITE license a floating license, would every user be able to pull a license from our server at the same time? Yes, the number of users that can use the license simultaneously=number of seats purchased If instead we chose to make the TEMAC SITE license node-locked, could we generate a separate node-locked license for every user at our location? Yes, that is on you. You can choose floating or node-locked. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
你好@ khal
请检查以下AR链接: https://www.xilinx.com/support/answers/45589.html 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @khal Please check the below AR link: https://www.xilinx.com/support/answers/45589.html Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨Rohit -Thanks的链接,但我不确定AR真的解决了我的问题。
只是寻找确认 - SITE和PROJ是否授权多用户许可? 如果它们是浮动的,多个用户可以同时从浮动许可证服务器中提取许可证吗? 如果它们是节点锁定的,我们是否可以为每个用户的计算机生成节点锁定许可证? 以上来自于谷歌翻译 以下为原文 Hi Rohit - Thanks for the link, but I'm not sure the AR really addresses my concern. Just looking for confirmation - Are SITE and PROJ licenses multi-user licenses? If they are floating, can multiple users pull a license at the same time from the floating license server? If they are node-locked, can we generate a node-locked license for each user's machine? |
@khal,
是的,SITE和PROJ许可证可以是节点锁定的也可以是浮动的。 SITE许可是否意味着在给定位置(以及5英里半径范围内)内的所有用户可以在必要时同时提取许可证?是 如果我们选择将TEMAC SITE许可证作为浮动许可证,那么每个用户是否能够同时从我们的服务器获取许可证? 是的,可以同时使用许可证的用户数量=购买的座位数量 如果我们选择使节点锁定的TEMAC SITE许可证,我们是否可以为我们所在位置的每个用户生成单独的节点锁定许可证? 是的,那就是你。 您可以选择浮动或节点锁定。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @khal, Yes, the SITE and PROJ licenses can be both node-locked or floating. Does a SITE license imply that all users at a given location (and within a 5 mile radius) can pull the license at the same time if necessary? Yes If we chose to make the TEMAC SITE license a floating license, would every user be able to pull a license from our server at the same time? Yes, the number of users that can use the license simultaneously=number of seats purchased If instead we chose to make the TEMAC SITE license node-locked, could we generate a separate node-locked license for every user at our location? Yes, that is on you. You can choose floating or node-locked. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
@khal,
您的查询是否已解决? 如果是,请通过将适当的答案标记为“接受为解决方案”来关闭此主题。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @khal, Is your query addressed? If yes, please close this thread by marking appropriate answer as "Accept as Solution". Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
441浏览 1评论
196浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 14:32 , Processed in 1.504889 second(s), Total 84, Slave 68 queries .
