我使用vivado 2016.我在warp v3板上做项目,因为我不能使用vivado。
但是我有ise webpack13.4,这对于没有付费许可证使用warpboard的所有功能都没用,所以可以帮我使用vivado付费许可证for is 13.4。 以上来自于谷歌翻译 以下为原文 Iam using vivado 2016. Iam doing project on warp v3 boards for that i can't use vivado. but i have ise webpack13.4, this isn't useful to all features to use warpboard without paid license, so can help me to use vivado paid license for ise 13.4. |
嗨@ ravikiran,
如果您购买了vivado许可证,则将获得ISE许可证。 您可以将该许可证用于V6。 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @ravikiran, If you have purchased vivado license, you will get ISE license included. You can use that license for V6. Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你好@ ravikiran,
正如同事@ arpansurhas正确指出的那样,任何购买新Vivado许可证的人都将自动免费获得ISE(同版)许可。 因此,您将/应该看到为Vivado添加一个许可证,并为ISE单独添加许可证。 这些天你不能购买ISE许可证,因为当你购买Vivado lic时它们是免费的。 希望这很清楚。 如果需要进一步的帮助,请告诉我。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @ravikiran, As the colleague @arpansur has correctly indicated, these days, anyone who’d purchased a new Vivado license will automatically receive an ISE (same edition) license for free. Therefore, you will/should see one license added for Vivado and separately - for ISE. You can’t purchase an ISE license these days, as they are come free when you purchased a Vivado lic. Hope this is clear. If further help is needed, please let me know. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2363 浏览 7 评论
2782 浏览 4 评论
2248 浏览 9 评论
3326 浏览 0 评论
2414 浏览 15 评论
734浏览 1评论
524浏览 1评论
337浏览 1评论
742浏览 0评论
1940浏览 0评论
GMT+8, 2024-11-10 14:28 , Processed in 0.919773 second(s), Total 47, Slave 42 queries .
