大家好
我用22伏电压为我的电机供电,具有以下寄存器值: KVAL注册0X10(HEX) OC SD_ DISABLE =不要在过流时断开桥接 当电压上升到24V(在orden中获得更多扭矩)时,发动机停止并失去其扭矩。我只需要再次以22V供电并且电机正常工作 谁知道我做错了什么..为什么要在24 V时准确停止电机? 感谢您的帮助 #l6470-24-volts_,电机停止 以上来自于谷歌翻译 以下为原文 Hi Everybody Im power my motor with 22 Volts with the following Register values: KVAL Register 0X10 (HEX) OC SD_ DISABLE = Do not schut down the bridges on overcurrent As the voltage rises to 24V (in orden to obtain more Torque) the engine stops and lose its Torque.. I Just need to power again with 22V and the motor works Anybody knows what im doing wrong.. Why stops the motor exactly on 24 V? Thank you for your help #l6470-24-volts_-motor-stop |
Ciao Edgar
我建议在https://my.st.com//public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards/AllItems.aspx上发布此帖子 论坛。 谢谢 再见 梁咏琪 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Ciao Edgar I suggest post this thread in the https://my.st.com//public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards/AllItems.aspx forum. Thanks Ciao Gigi Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
2779 浏览 1 评论
3251 浏览 1 评论
1824 浏览 1 评论
3667 浏览 6 评论
6062 浏览 21 评论
1347浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
373浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
467浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
292浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
214浏览 2评论
GMT+8, 2025-1-11 09:25 , Processed in 1.013040 second(s), Total 77, Slave 61 queries .
