你好,
我对BCM433W的OTA有点困惑。 到目前为止我所学到的是(如果我错了,请给予回应)。 1)OTA(1)将在BCM9433WYAVN上工作,而OTA2不支持该模块。 2)OTA(1)支持的唯一方法是通过DOC中的SOFTAP和HTTP服务器。 我有不同的要求, (1)我们的产品有移动应用程序(Android,iOS),我只想通过那个应用程序更新固件。 (1.1)如果我的第一点与OTA(1)是可能的,那么,有可能通过修改OTAYAPP设备不会进入软模式,而是保持与路由器的连接。 AP作为站和用户也连接到相同的AP,因此用户将从我们的移动应用程序更新设备固件。 (2)如果BCM433W的固件可能比它的最佳方法更新,那么有可能通过蓝牙来更新固件。我们的应用程序将更新BCM433W的应用固件BLE。 如果已经为这个开发了源代码,那么这是好的,但是如果不是,那么也请让我知道它是否有可能通过修改或创建源代码中的一个以上解决方案。 慢慢来,但一定要了解这方面的信息。 BLE固件升级将对我们有利,因为我们的其他终端设备使用BLE、BCM9433WYAVN进行通信,我们希望在BLE和云上的服务器之间使用FRO桥。 谢谢和问候, 哈迪克哈巴尔 以上来自于百度翻译 以下为原文 Hi, I am little confused about OTA of BCM4343W. what I learn so far is ( kindly give response if I am wrong), 1) OTA(1) will work on BCM94343W_AVN and OTA2 is not supported by this module. 2) Only method supported by OTA(1) is through softAP and Http Server as mentioned in Doc. I have different requirement, (1) We have mobile app (android,iOS) for our product and I want to update firmware by that app only. (1.1) If my 1st point is possible with OTA(1) then, is it possible that by modifying OTA_App device will not go to softAP mode but instead it stays connected to router's AP as station and user is also connected to same AP so user will update device firmware from our mobile app. (2) Is it possible to update firmware of BCM4343W by bluetooth if its possible than its best approach for me. our app will update application firmware of BCM4343W by BLE. If there is source code already developed for this then thats good but if not then also, please let me know if its possible to have one of the above solution by modifying or creating source code. Take your time but be sure about info on this. Firmware upgrade by BLE will be good for us as our other end devices are communicating using BLE, BCM94343W_AVN we want to use fro bridge between BLE and and our Server on Cloud. Thanks and Regards, Hardik harpal |
首先,你对OTA的理解是正确的。
现在谈谈你想通过移动应用程序更新应用程序的OTA的用法。你提到的第一点是可能的。如果您的手机上有图片(上载),您可以从手机上更新应用程序。图像是要更新的应用程序的bin文件。如果用户设备和移动电话连接到同一AP,即在同一网络中,则可以将图像从电话上传到用户设备。 还有一点我想说清楚:当你说固件时,它意味着在设备上运行的应用固件?它并不意味着设备的WiFi固件。如果我在这里漏掉东西,请给我回信。 要回答您的第二个问题,可以通过蓝牙升级应用程序,但速度非常低。除此之外,在Wiced没有样本的例子。我们推荐使用WiFi为OTA,还有一个示例应用程序。但是使用BT,你需要为OTA创建自己的源代码。 以上来自于百度翻译 以下为原文 Firstly your understanding about OTA is correct. Now about your usage of OTA where you want to update an application through a mobile app. The first point you mentioned is possible. You can update the application from your mobile phone if you have the image(to be uploaded) in your phone. The image is the bin file of the application that you want to update. If the user device and mobile phone are connected to the same AP, i.e., in the same network, the image can be uploaded from the phone to the user device. One more thing I wanted to make clear: When you say firmware, it means the application firmware running on the device? It does not mean the wifi firmware of the device. Please write back to me if I'm missing something here. To answer your second question, It is possible to upgrade application over Bluetooth but the speed is very less. besides there is no sample example for doing so in Wiced. We recommend using Wifi for OTA and there is a sample application also. But with BT, you need to create your own source code for OTA. |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
411浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-24 13:22 , Processed in 0.688121 second(s), Total 43, Slave 38 queries .
