我有需要的环境:
############################# export JAVA_HOME = / usr / lib / jvm / java export JRE_HOME = $ {JAVA_HOME} / jre export CLASSPATH =。:$ {JAVA_HOME} / lib:$ {JRE_HOME} / lib export PATH = $ {JAVA_HOME} / bin:$ PATH #xilinxexport XILINXD_LICENSE_FILE = / opt / Xilinx / Vivado_license_2037_2016.3.licalias vivado ='/ opt / Xilinx / Vivado / 2016.3 / bin / vivado'source /opt/Xilinx/Vivado/2016.3/settings64.shexport SWT_GTK3 = 0 if [-n “$ {LD_LIBRARY_PATH}”]; 然后#export LD_LIBRARY_PATH =“/ opt / Xilinx / Vivado / 2016.3 / lib / lnx64.o:”$ LD_LIBRARY_PATH export LD_LIBRARY_PATH =“/ opt / Xilinx / SDK / 2016.3 / lib / lnx64.o:" $ LD_LIBRARY_PATHelse #export LD_LIBRARY_PATH = “/opt/Xilinx/Vivado/2016.3/lib/lnx64.o”export LD_LIBRARY_PATH =“/ opt / Xilinx / SDK / 2016.3 / lib / lnx64.o”fi ############################### 当我运行'/opt/Xilinx/SDK/2016.3/eclipse/lnx64.o/eclipse'时,会出现以下错误,然后退出。 如何根据信息找到问题? ###################### JVM终止了。 退出代码= 6 / usr / lib / jvm / java / bin / java-Xms64m-Xmx512m-jar /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher_1.3.100。 v20150511-1540.jar-os linux-ws gtk-arch x86_64-showsplash /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/com.xilinx.sdk.product_1.0.0.201610110148.jar/splash。 bmp-launcher /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o/eclipse-name Eclipse - launcher.library /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/org.eclipse.equinox .launcher.gtk.linux.x86_64_1.1.300.v20150602-1417 / eclipse_1612.so-startup /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher_1.3.100.v20150511- 1540.jar - launcher.overrideVmargs-exitdata 22b0014-vm / usr / lib / jvm / java / bin / java -vmargs-Xms64m-Xmx512m-jar /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins /org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar 以上来自于谷歌翻译 以下为原文 I have soure the needed env: ############################# export JAVA_HOME=/usr/lib/jvm/java export JRE_HOME=${JAVA_HOME}/jre export CLASSPATH=.:${JAVA_HOME}/lib:${JRE_HOME}/lib export PATH=${JAVA_HOME}/bin:$PATH # xilinx export XILINXD_LICENSE_FILE=/opt/Xilinx/Vivado_license_2037_2016.3.lic alias vivado='/opt/Xilinx/Vivado/2016.3/bin/vivado' source /opt/Xilinx/Vivado/2016.3/settings64.sh export SWT_GTK3=0 if [ -n "${LD_LIBRARY_PATH}" ]; then #export LD_LIBRARY_PATH="/opt/Xilinx/Vivado/2016.3/lib/lnx64.o:"$LD_LIBRARY_PATH export LD_LIBRARY_PATH="/opt/Xilinx/SDK/2016.3/lib/lnx64.o:"$LD_LIBRARY_PATH else #export LD_LIBRARY_PATH="/opt/Xilinx/Vivado/2016.3/lib/lnx64.o" export LD_LIBRARY_PATH="/opt/Xilinx/SDK/2016.3/lib/lnx64.o" fi ############################### When I run '/opt/Xilinx/SDK/2016.3/eclipse/lnx64.o/eclipse', it appears the following error, and exited. How can I find the problem according to the info? ###################### JVM terminated. Exit code=6 /usr/lib/jvm/java/bin/java -Xms64m -Xmx512m -jar /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar -os linux -ws gtk -arch x86_64 -showsplash /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/com.xilinx.sdk.product_1.0.0.201610110148.jar/splash.bmp -launcher /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o/eclipse -name Eclipse --launcher.library /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.300.v20150602-1417/eclipse_1612.so -startup /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar --launcher.overrideVmargs -exitdata 22b0014 -vm /usr/lib/jvm/java/bin/java -vmargs -Xms64m -Xmx512m -jar /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar |
7个回答
@luoyanghero
试试吧: 来源/opt/Xilinx/Vivado/2016.3/settings64.sh export SWT_GTK3 = 0 xsdk vitorian.com ---我们这样做很有趣。 总是给予赞誉。 如果您的问题得到解答,请接受解决方案。我不会回复个人信息 - 请改用论坛。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @luoyanghero Try just this: source /opt/Xilinx/Vivado/2016.3/settings64.shexport SWT_GTK3=0 xsdk vitorian.com --- We do this for fun. Always give kudos. Accept as solution if your question was answered. I will not answer to personal messages - use the forums instead.View solution in original post |
@luoyanghero
试试吧: 来源/opt/Xilinx/Vivado/2016.3/settings64.sh export SWT_GTK3 = 0 xsdk vitorian.com ---我们这样做很有趣。 总是给予赞誉。 如果您的问题得到解答,请接受解决方案。我不会回复个人信息 - 请改用论坛。 以上来自于谷歌翻译 以下为原文 @luoyanghero Try just this: source /opt/Xilinx/Vivado/2016.3/settings64.shexport SWT_GTK3=0 xsdk vitorian.com --- We do this for fun. Always give kudos. Accept as solution if your question was answered. I will not answer to personal messages - use the forums instead. |
谢谢,它可以启动SDK,并且可以成功编译我的项目。在我启动SDK之后,我使用了ldd:#######################:〜/ t
/ dbg_vivado $ ldd /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o/eclipse linux-vdso.so.1 =>(0x00007ffedefa4000)libpthread.so.0 => / lib / x86_64-linux-gnu / libpthread。 so.0(0x00007f05f0eca000)libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2(0x00007f05f0cc6000)libc.so.6 => /lib/x86_64-linux-gnu/libc.so。 6(0x00007f05f08fc000)/lib64/ld-linux-x86-64.so.2(0x00007f05f10e7000):~/t/dbg_vivado $ ldd /opt/Xilinx/SDK/2016.3/bin/unwrapped/lnx64.o/rdi_xsdk linux-vdso .so.1 =>(0x00007ffe905a3000)libboost_filesystem.so => /usr/lib/x86_64-linux-gnu/libboost_filesystem.so(0x00007f26d39c9000)libboost_program_options.so => /usr/lib/x86_64-linux-gnu/libboost_program_options.so (0x00007f26d374b000)librdi_common.so =>未找到librdi_commonversion.so =>未找到libstdc ++。so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6(0x00007f26d33c9000)libgcc_s.so.1 => / LIB / x86_64的-Linux的GNU / libgcc_ s.so.1(0x00007f26d31b3000)libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0(0x00007f26d2f96000)libc.so.6 => / lib / x86_64-linux-gnu / libc。 so.6(0x00007f26d2bcc000)libboost_system.so.1.58.0 => /usr/lib/x86_64-linux-gnu/libboost_system.so.1.58.0(0x00007f26d29c8000)libm.so.6 => / lib / x86_64-linux- gnu / libm.so.6(0x00007f26d26bf000)/lib64/ld-linux-x86-64.so.2(0x00007f26d3be1000)####################### ### rdi_xsdk仍然没有完整的链接lib.Before我使用了错误的启动命令:/opt/Xilinx/SDK/2016.3/eclipse/lnx64.o/eclipsenot xsdk。 以上来自于谷歌翻译 以下为原文 Thanks, It can launch SDK, and can compile my project successfully. After I launched SDK, I use ldd: ####################### :~/t/dbg_vivado$ ldd /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o/eclipse linux-vdso.so.1 => (0x00007ffedefa4000) libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f05f0eca000) libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f05f0cc6000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f05f08fc000) /lib64/ld-linux-x86-64.so.2 (0x00007f05f10e7000) :~/t/dbg_vivado$ ldd /opt/Xilinx/SDK/2016.3/bin/unwrapped/lnx64.o/rdi_xsdk linux-vdso.so.1 => (0x00007ffe905a3000) libboost_filesystem.so => /usr/lib/x86_64-linux-gnu/libboost_filesystem.so (0x00007f26d39c9000) libboost_program_options.so => /usr/lib/x86_64-linux-gnu/libboost_program_options.so (0x00007f26d374b000) librdi_common.so => not found librdi_commonversion.so => not found libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f26d33c9000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f26d31b3000) libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f26d2f96000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f26d2bcc000) libboost_system.so.1.58.0 => /usr/lib/x86_64-linux-gnu/libboost_system.so.1.58.0 (0x00007f26d29c8000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f26d26bf000) /lib64/ld-linux-x86-64.so.2 (0x00007f26d3be1000) ########################## rdi_xsdk still don't have complete linked lib. Before I used a wrong launch command: /opt/Xilinx/SDK/2016.3/eclipse/lnx64.o/eclipse not xsdk. |
我导出xilinx LD库,rdi_xsdk有完整的链接库。######## export LD_LIBRARY_PATH =“/ opt / Xilinx / Vivado / 2016.3 / lib / lnx64.o:" $ LD_LIBRARY_PATH ########
但我的gvim无法启动。######## / usr / bin / gvim:/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libstdc++.so.6:未找到版本`CXXABI_1.3.8' (需要/usr/lib/x86_64-linux-gnu/libicuuc.so.55)########My gvim链接lib被Xilinx lib取代。所以Xilinx工具无法同时与gvim一起运行 。 现在我将.bashrc文件拆分为两个。 一个基本的env包括gvim(.bashrc_basic),另一个只包括xilinx env(.bashrc_xil)。 当我运行xilinx工具时,我打开一个新的cmd窗口,并且源.bashrc_xil,这个窗口只运行xilinx工具。 这个动作可以解决我的问题。还有另一种方法让我在同一个cmd窗口中同时运行xilinx工具和gvim吗? 以上来自于谷歌翻译 以下为原文 I export xilinx LD library, rdi_xsdk has full linked lib. ######## export LD_LIBRARY_PATH="/opt/Xilinx/Vivado/2016.3/lib/lnx64.o:"$LD_LIBRARY_PATH ######## But my gvim cannot launch. ######## /usr/bin/gvim: /opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/lib/x86_64-linux-gnu/libicuuc.so.55) ######## My gvim linked lib is replaced by Xilinx lib. So Xilinx tool can not run with gvim at the same time. Now I split the .bashrc file as two. one basic env include gvim(.bashrc_basic), another only include xilinx env(.bashrc_xil). When I run xilinx tool, I open a new cmd window, and source .bashrc_xil, this window only run xilinx tool. The action can solve my problem. Is there another way makes me run xilinx tool and gvim the same time in same cmd window? |
@luoyanghero本机二进制文件和采购xilinx存在一些问题。
最着名的是awk。 您可以尝试不使用settings64.sh并创建自己的bash脚本,仅修改PATH(不触及LD_LIBRARY_PATH)。 或者可能将LD_LIBRARY_PATH保存到临时变量,source settings64.sh然后从temp恢复LD_LIBRARY_PATH。 vitorian.com ---我们这样做很有趣。 总是给予赞誉。 如果您的问题得到解答,请接受解决方案。我不会回复个人信息 - 请改用论坛。 以上来自于谷歌翻译 以下为原文 @luoyanghero There are a few problems with native binaries and sourcing xilinx. The most famous is with awk. You can try not to source settings64.sh and create your own bash script that modifies PATH only (without touching LD_LIBRARY_PATH). Or perhaps save LD_LIBRARY_PATH to a temp variable, source settings64.sh and then restore LD_LIBRARY_PATH from temp. vitorian.com --- We do this for fun. Always give kudos. Accept as solution if your question was answered. I will not answer to personal messages - use the forums instead. |
如果我将LD_LIBRARY_PATH保存到临时变量,并在启动vivado时临时加载库。
我该怎么做? 以上来自于谷歌翻译 以下为原文 If I save the LD_LIBRARY_PATH to a temp variable, and temp load the library when launch vivado. How can I do it? |
@luoyanghero的想法是不允许脚本更改LD_LIBRARY_PATH。
vitorian.com ---我们这样做很有趣。 总是给予赞誉。 如果您的问题得到解答,请接受解决方案。我不会回复个人信息 - 请改用论坛。 以上来自于谷歌翻译 以下为原文 @luoyanghero The idea is not allowing the script to change LD_LIBRARY_PATH. vitorian.com --- We do this for fun. Always give kudos. Accept as solution if your question was answered. I will not answer to personal messages - use the forums instead. |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1172浏览 1评论
585浏览 1评论
451浏览 1评论
2005浏览 0评论
729浏览 0评论
GMT+8, 2024-12-23 16:09 , Processed in 1.308162 second(s), Total 88, Slave 72 queries .
