扫一扫,分享给好友
你好,
任何经历过PSoC Creator的人都不能在两个或更多个实例运行时成功构建一个项目?在我的例子中,PSoC Creator似乎无法路由硬件原理部分成功,导致未连接的网络等。我已经用另一个项目运行了PSoC Creator的另一个实例,但是没有构建这个项目(只是为了复制一些代码片段)。唯一值得一提的另一个项目是,我已经启动了USB组件定制器。 我使用最新的4.1版本。我会尝试复制它,可能会打开一个威廉希尔官方网站 支持的案例,但我想问一下是否有其他人正在体验这一点。 当做, 拉尔夫 以上来自于百度翻译 以下为原文 Hi, anyone experiencing PSoC Creator not able to build a project successful when two or more instances are running? In my case, it seems that PSoC Creator is not able to route the hardware schematic part successful, resulting in unconnected nets, etc. I had running another instance of PSoC Creator with another project, but didn't build that project (was just for copying some code snippets). The only thing worth to mention for that other project was that I've started the USB component customizer. I'm using latest 4.1 version. I'll try to reproduce it, may open a case on technical support, but I want to ask if anyone else is experiencing this. Regards, Ralf |
3个回答
请提及在Currist4.1 UpDeDe1中重现此问题的步骤供我们研究
以上来自于百度翻译 以下为原文 Please mention the steps to reproduce this issue in Creator4.1 Update1 for us to investigate |
我有规则地打开4到8个创建者4.1的实例,从来没有任何错误。
运行Windows Vista或Windows 10。你运行虚拟操作系统作为VMware吗? 鲍勃 以上来自于百度翻译 以下为原文 I have regulary open 4 to 8 instances of Creator 4.1 and never had any errors. Running Windows Vista or Windows 10. Are you running a virtual OS as VMware? Bob |
你好,
我试图复制它,但是现在它看起来很稳定。仍在调查中。一旦我有这种行为,我就报告。 鲍勃:没有VM或其他任何东西。受影响的工作区包含大约十个项目,总是为当前项目而不是整个工作空间构建。在发生错误的时候,我用一个USB项目打开了第二个实例来查看代码片段。但没有什么可以解释这种行为。 当做 以上来自于百度翻译 以下为原文 Hi, @anks: I tried to reproduce it, but currently it seems to be stable. Still investigating. As soon as I have such a behaviour again, I'll report. @Bob: No VM or anything else. The affected workspace contains about ten projects, build is always made for current project, not whole workspace. At the time when the error occured, I had a 2nd instance open with a single USB project to review a code snippet. But nothing obvious which would explain the behaviour. Regards |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 16:50 , Processed in 0.613952 second(s), Total 48, Slave 43 queries .
