你好,
我与FX3一起工作,从CPLD传输计数器数据。我尝试通过改变GPIF接口和IXO配置在FX3到16位和8位。 IOICONG.ISDQ32位=CyFLY; IOICONtiON.UUEART=CyTrand; IOICONTRO.LPPMODE = CYU-U3PIOIOMIXIXLPPUUARTY; 但它不起作用。 它具有32和24位数据,并且不改变IOIO配置。原因何在? 如何将其更改为16位数据? 以上来自于百度翻译 以下为原文 Hi, I am working with FX3 to transfer Counter data from CPLD. I tried it by changing GPIF interface and IO_configuration in FX3 to 16 bit and 8-bit. io_Config.isDQ32Bit = CyFalse; io_Config.useUart = CyTrue; io_Config.lppMode = CY_U3P_IO_MATRIX_LPP_UART_ONLY; But it was not working. It was working well with 32 and 24 bit data with and without changing IO_Configuration. what is the reason for that? How should I change it to 16-bit data? |
请澄清“不工作”是什么意思。
请添加USB调试消息并检查IOMATRAIX是否已配置。如果不是,您在UART上得到什么错误消息。 如果您可以共享您的固件,我们将能够看到这个问题,并帮助您更好。 以上来自于百度翻译 以下为原文 Please clarify what do you mean by ' not working'. Please add USB debug messages and check if the IOMatrix is getting configured. If not, what error message do you get on the UART. If you can share your firmware, we will be able to see the issue and help you better. |
741个成员聚集在这个小组
加入小组2004 浏览 1 评论
1763 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
277浏览 2评论
171浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 17:43 , Processed in 0.888328 second(s), Total 76, Slave 60 queries .
