问这个问题的原因是我正在寻找减少参考板功耗的方法。我知道WiFi的省电机制。我正在寻找除WiFi省电机制以外的途径。在我处理的情况下,两个WFI模块是在ad hoc网络配置中,并且在短距离(2或3英尺)彼此。因此,WiFi的完全发射功率不是必需的。如果WICE API提供了一种机制来抑制WiFi的发射功率,那么这就转化为省电和更长的电池寿命。
以上来自于百度翻译 以下为原文 The reason for asking this question is that I am looking for ways to reduce the power consumption of the reference board. I know about the power save mechanisms of the WiFi. I am looking for avenues other than the WiFi power save mechanisms. In the case that I am dealing with, the two WFi modules are in an ad hoc network configuration and are at a short distance ( 2 or 3 ft) from each other. So, the full transmit power of the WiFi is not necessary. IF the WICED API offers a mechanism to throttle the transmit power of the WiFi then that translates to power save and longer battery life. |
你好,
来自赛普里斯的问候!WAPI的API不提供任何机制来节制发射功率。可以修改发送功率的WL命令仅适用于MFGTY固件映像(不用于生产固件),其目的是在电路板测试和调谐目的期间使用。对于进一步的引用,您可以通过WICED MFG202应用程序注释,位于WSDICSDK的DOC文件夹中。发射功率一般由存储在NVRAM中的几个功率放大器增益参数控制。这些参数的值受该地区的监管限制的限制。你能告诉我为什么你不想使用Wi-Fi的省电机制吗? 当做, 拉克蒂姆 以上来自于百度翻译 以下为原文 Hello, Greetings from Cypress! WICED APIs do not offer any mechanism to throttle the transmit power. The wl commands that can modify the transmit power are only valid with mfg_test firmware image (not for production firmware) which is intended to use during board testing and tuning purposes. For further refernce on the same, you can go through the WICED-MFG202 application note located inside the doc folder of WICED SDK. The transmit power is generally controlled by a few power amplifier gain parameters stored in NVRAM. The values of these parameters are limited by regulatory restrictions in that region. Could you please let me know why you do not want to use the power save mechansims of Wi-Fi? Regards, Raktim. |
757个成员聚集在这个小组
加入小组2144 浏览 1 评论
1888 浏览 1 评论
3707 浏览 1 评论
1821 浏览 6 评论
1568 浏览 1 评论
769浏览 2评论
522浏览 2评论
478浏览 2评论
436浏览 2评论
1126浏览 2评论
GMT+8, 2025-2-12 18:37 , Processed in 0.814072 second(s), Total 45, Slave 39 queries .
