我正在从事FPGA项目,特别是我有Xilinx Zynq双核ARM A9 XC7Z010(脑a2和脑h2)。
我的安装文件(“brain_reference_design_2017_02_01.img”)已损坏(意大利语“Il file di immaginediscoèdanneggiato”)。 我试图从zip重新解析文件,但它是相同的,我也尝试使用Daemon Tools Lite这种文件,但没有任何作用(无论如何我的电脑是Windows 10)。 请帮忙。 以上来自于谷歌翻译 以下为原文 I'm working in a FPGA project, in particular I have Xilinx Zynq Dual-core ARM A9 XC7Z010 (both brain a2 and brain h2). My installation file ("brain_reference_design_2017_02_01.img") is corrupted (in italian "Il file di immagine disco è danneggiato"). I tried to re-extrct the file from zip but it is the same, i also tried to use Daemon Tools Lite for this kind of file but nothing works (anyway my pc is windows 10). Please help. |
@ emanuele.zh,
尝试再次下载该文件。 使用Windows中的校验和计算器验证其校验和(如果您在某处提到了校验和)。 然后尝试解压缩文件。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @emanuele.zh, Try downloading the file again. Verify its checksum using Checksum Calculator in Windows(if you have the checksum mentioned somewhere). Then try to extract the file. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
2363 浏览 7 评论
2782 浏览 4 评论
2248 浏览 9 评论
3326 浏览 0 评论
2414 浏览 15 评论
735浏览 1评论
525浏览 1评论
338浏览 1评论
743浏览 0评论
1941浏览 0评论
GMT+8, 2024-11-10 16:47 , Processed in 0.883375 second(s), Total 44, Slave 39 queries .
