您好,以后是否可以从sharepoint加载序列库?
目前只能从网络驱动器。 感谢您的信息! 此致,Willi_2008 以上来自于谷歌翻译 以下为原文 Hello, will it be possible in the future to load the sequence libraries from a sharepoint ? At the moment is only possible from network drives. Thank for your information !! Regards, Willi_2008 |
您好Willi_2008,目前还没有计划从sharepoint加载序列库。
您能与我们分享一下这个应用程序在贵公司的使用范围吗? 我们需要对此进行评估。 谢谢。 此致,辛西娅 以上来自于谷歌翻译 以下为原文 Hi Willi_2008, Currently there are not yet plan to load the sequence library from sharepoint. Could you share with us on how extensive this application would be used in your company? We will need to evaluate this. Thanks. Regards, Cynthia |
xiaoqi110 发表于 2018-12-21 12:27 你好辛西娅,非常感谢你的回复! 我们想从2014年开始介绍子序列库。要在我们公司的不同位置共享我们的库,最简单的方法是设置一个sharepoint。 所以请考虑一下这种可能性。 谢谢 !! Willi_2008 以上来自于谷歌翻译 以下为原文 Hello Cynthia, thank you very much for your reply ! We want to introduce the subsequences libraries starting with 2014. To share our libraries with different locations in our company the easiest way was to setup a sharepoint. So pls think about this possibility. Thank you !! Willi_2008 |
1410 浏览 0 评论
2425 浏览 1 评论
2281 浏览 1 评论
2118 浏览 5 评论
3038 浏览 3 评论
1524浏览 1评论
850浏览 0评论
1286浏览 0评论
1410浏览 0评论
GMT+8, 2025-3-13 00:07 , Processed in 1.256658 second(s), Total 46, Slave 40 queries .
