你好:
我在Windows 10 64.bit上运行ISE Design Suite 14.1。 我有许可证文件,一切正常,直到我尝试为FPGA板Nexys 2 Spartan3E-500生成编程文件。 我收到了错误 没有'ISE'或'WebPack'功能版本2012.04可用 地图:258 - 尝试获取此体系结构的许可证时遇到问题。 我已经在大约一个月前下载了该软件并生成了许可文件,但无法找到解决此问题的方法。 如果有人已经知道解决方案,我会立即附上许可证文件。 请帮忙。 问候 Xilinx.lic 2 KB 以上来自于谷歌翻译 以下为原文 Hi: I'm running ISE Design Suite 14.1 on windows 10 64.bit. I have license file and everything works fine until I try to generate programing file for FPGA board Nexys 2 Spartan3E-500. I get the error No 'ISE' nor 'WebPack' feature version 2012.04 was available Map:258 - A problem was encountered attempting to get the license for this architecture. I have downloaded the software and generated the license file this year about a month ago, and can't find the solution to this problem. I attach the license file immediately in case someone already knows the solution. Please help. Regards Xilinx.lic 2 KB |
6个回答
您好@ pdiaz2
此处附带的许可证文件是Vivado WebPACK许可证。 您需要ISE WebPACK许可证才能为此设备生成比特流。 要生成ISE WebPACK许可证,请按照生成Vivado WebPACK许可证所遵循的相同步骤操作。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @pdiaz2 The license file attached here is Vivado WebPACK license. You need ISE WebPACK license to generate bitstream for this device. To generate ISE WebPACK license, follow the same steps that you followed for generating Vivado WebPACK license. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
维奈:
当我尝试获得ISE许可证时,该选项不会出现在我可以生成的许可证中。 我只在下面的截图中附上选项。 我之前安装的那个包括(或者我被认为是)ISE许可证。 感谢您的帮助,我没有在任何地方找到解决方案。 以上来自于谷歌翻译 以下为原文 Vinay: When I try to get an ISE License, the option doesnt appear in the licenses I can generate. I only get the options attached in teh screenshot below. The one I installed earlier included (or I was led to believe that) the ISE License. Thanks for your help, I haven't found a solution anywhere. |
你好@ pdiaz2,
如果您已生成ISE WebPack许可证,则它将出现在“产品许可”页面的“管理许可证”选项卡中 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @pdiaz2, If you have already generated ISE WebPack license, it will be present in 'Manage License' tab on Product Licensing page Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
阿希什,
我在Manage License中拥有的唯一许可是上面提到的许可。 我曾在旧计算机上安装过ISE许可证,今年就为此创建了此许可证。 附件是管理许可证的图像。 我很想想也许我应该下载Vivado Design Suite:HL Webpack 2015和早期许可证。 或者这可能是主持人的问题? 以上来自于谷歌翻译 以下为原文 Ashish, The only license I have in Manage License is the one mentioned above. I had once installed an ISE license on an older computer, and just this year created this license for this one. Attached is an image of Manage License. I am tempted to think that maybe I should download Vivado Design Suite: HL Webpack 2015 and Earlier License. Or could it be a problem of the host? |
你好@ pdiaz2
您是否可以在此处提出将ISE WebPACK许可添加到您的帐户的请求? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @pdiaz2 Can you raise a request here to add ISE WebPACK license to your account? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay,
谢谢你的帮助,但我自己解决了这个问题。 为了记录,案例和解决方案是: 案件: 在2014年在旧计算机上安装了ISE项目导航器。 下载该计算机的ISE Webpack许可证 下载的许可证与其他许可证的识别方式不同(据我所知,Pablo-PC,我已下载的另一个,并且在该选项卡中有*) 今年(2016年)为另一台计算机下载了ISE项目导航器(与2014年的版本相同)。 下载并激活许可证(不是ISE Webpack许可证,某种类型的Vivado)以在此新计算机上使用此项目导航器。 该软件完全正常,直到尝试在FPGA上实现它(Nexys 3和Basys 2) 解: 再次释放旧许可证(ISE Webpack)(无法记住我是如何做到的,但它有点表明我可以在我的生活中再做两次)并且Pablo-PC的标签变成了* 使用此新许可证在新计算机上下载了ISE Webpack许可证并激活了ISE项目导航器。 解决了! 谢谢 以上来自于谷歌翻译 以下为原文 Hi Vinay, Thanks for your help, but I solved the problem that day by myself. For the record, the case and solution is: CASE: Had installed ISE project navigator on an older computer in 2014. Downloaded ISE Webpack License for that computer The License downloaded was identified differently than the others (it said Pablo-PC I believe, where the other one I had downloaded has and * in that tab) Downloaded ISE project navigator (same version as the one in 2014) for another computer this year (2016). Downloaded and activated a license (not an ISE Webpack license, a Vivado of some sort) to use this project navigator on this new computer. The software worked perfectly fine until trying to implement it on an FPGA (Nexys 3 and Basys 2) SOLUTION: Freed the older license (ISE Webpack) again (cant remember exactly how I did it, but it sort of showed I could do that two more times in my life) and the tab that was Pablo-PC became * Downloaded the ISE Webpack license on new computer and activated ISE project navigator with this new license. Solved! Thanks though |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3414 浏览 0 评论
2506 浏览 15 评论
2309浏览 1评论
649浏览 1评论
514浏览 1评论
2062浏览 0评论
790浏览 0评论
GMT+8, 2025-2-12 02:18 , Processed in 1.280065 second(s), Total 54, Slave 48 queries .
