单击“开始”菜单中的“Vivado 2016.1”按钮后:
然后我点击修复,然后: 但事情并没有好转,因为Vivado没有按照应有的方式发布,相反,几秒钟之后,这就出现了: 经过多次尝试但只得到了相同的结果,Itried在启动Vivado之前运行C: Xilinx Vivado 2016.1 tps win64 vcredist_x64.exe,然而,没有任何改变。 希望有人能帮帮我。谢谢你。 附: 这个问题出现在我大约两周前升级Windows 10之后。 在此之前,一切都很精细。 我当时正在Win10上使用Vivado 2015.4。今天我安装了Vivado 2016.1,看看这个问题是否能够解决,但........帮助。 以上来自于谷歌翻译 以下为原文 After clicking the button " Vivado 2016.1" in Start Menu : then I click Repair, and : But things did not get better because Vivado didn't launch as it should be, instead, several second later, this come : After many times trying but only got the same result, I tried to run C:XilinxVivado2016.1tpswin64vcredist_x64.exe before launching Vivado, however, nothing changed. Hope someone could help me out.Thanks a lot. P.s. this issue come out after I updeted Windows 10 about 2 weeks ago. Before that, everything was fine. I was using Vivado 2015.4 on Win10 at that time. Today I installed Vivado 2016.1 to see whether this problem be solved but........help. |
4个回答
请确保您满足软件要求。
如果默认启用,则禁用Web Talk数据。 请查看这些ARshttp://www.xilinx.com/support/answers/59304.htmlhttp://www.xilinx.com/support/answers/56148.html 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 please make sure you are fulfilling the software requirement. Disable web talk data if enabled by default. Check these ARs http://www.xilinx.com/support/answers/59304.html http://www.xilinx.com/support/answers/56148.html Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
在微软的最新更新(2016年6月25日前一周)之后,我收到同样的消息。
它在更新之前有效。 谁有运气? 以上来自于谷歌翻译 以下为原文 I'm getting the same message, following microsoft's latest update (week before 6/25/2016). It worked before the update. anyone having any luck? |
嗨@ severusitach,
您是否可以尝试删除2012年之后发布的Microsoft可再发行组件?保留Microsoft Visual C ++ 2012 Redistributable(x64)并删除2013或2015版本(如果有)。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @severusitach, Can you try removing the Microsoft redistributables that came after 2012? Keep Microsoft Visual C++ 2012 Redistributable(x64) and delete the 2013 or 2015 version if you have them. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
我终于能够通过将xvcredist.exe重命名为xvcredist_save.exe来运行vivado 2016.1,从而有效地隐藏它。
此文件位于C: Xilinx Vivado 2016.1 tps win64中 以上来自于谷歌翻译 以下为原文 I was finally able to get vivado 2016.1 running by renaming xvcredist.exe to xvcredist_save.exe, effectively hiding it. This file is in C:XilinxVivado2016.1tpswin64 |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1176浏览 1评论
587浏览 1评论
451浏览 1评论
2005浏览 0评论
731浏览 0评论
GMT+8, 2024-12-23 19:42 , Processed in 1.176446 second(s), Total 49, Slave 44 queries .
