扫一扫,分享给好友
我刚刚在Ubuntu 14.04 LTS机器上安装了Vivado 2016.1,该机器之前安装了2014和2015版本且工作正常。
安装程序没有错误并成功完成。 当我尝试启动Vivado时,我收到此消息: bp @ bp:/opt/Xilinx/Vivado/2016.1$ source settings64.shbp@bp:/opt/Xilinx/Vivado/2016.1$ bin / vivado ****** Vivado v2016.1(64位)**** SW Build 1538259 on Fri Apr 8 15:45:23 MDT 2016 **** IP Build 1537824 on Fri Apr 8 04:28:57 MDT 2016 **版权所有1986-2016 Xilinx,Inc。保留所有权利。 错误:[Common 17-356]执行“debug :: placer_monitor -start”时无法安装所有用户apps.invalid命令名称“debug :: placer_monitor”(文件“/opt/Xilinx/Vivado/2016.1/lib/scripts/ rdi / products / Vivado.tcl“第58行”INFO:[Common 17-206] 2016年4月25日星期一12:41:43退出Vivado ... 我安装了Vivado作为我的常规用户帐户,并且所有相关的Xilinxdirector都拥有我的用户的完全权限(甚至在〜/ .Xil,〜/ .Xilinx和/ opt / Xilinx上尝试过chmod -R 777),我也尝试过复制XilinxTclStore 文件夹到〜/ .Xilinx中关于AR#62908的正确位置并且也没有帮助。 知道什么可能是错的吗? 以上来自于谷歌翻译 以下为原文 I just installed Vivado 2016.1 on an Ubuntu 14.04 LTS machine that previously had 2014 and 2015 versions installed and working correctly. The installer had no errors and finished successfully. I am getting this message when I attempt to start Vivado: bp@bp:/opt/Xilinx/Vivado/2016.1$ source settings64.sh bp@bp:/opt/Xilinx/Vivado/2016.1$ bin/vivado ****** Vivado v2016.1 (64-bit) **** SW Build 1538259 on Fri Apr 8 15:45:23 MDT 2016 **** IP Build 1537824 on Fri Apr 8 04:28:57 MDT 2016 ** Copyright 1986-2016 Xilinx, Inc. All Rights Reserved. ERROR: [Common 17-356] Failed to install all user apps. invalid command name "debug::placer_monitor" while executing "debug::placer_monitor -start" (file "/opt/Xilinx/Vivado/2016.1/lib/scripts/rdi/products/Vivado.tcl" line 58) INFO: [Common 17-206] Exiting Vivado at Mon Apr 25 12:41:43 2016... I installed Vivado as my regular user account and all relevant Xilinx directories have full permissions for my user (even tried chmod -R 777 on ~/.Xil, ~/.Xilinx and /opt/Xilinx), I've also tried copying the XilinxTclStore folder into the right place in ~/.Xilinx with regards to AR#62908 and that did not help either. Any idea what could be wrong? |
5个回答
按照此AR http://www.xilinx.com/support/answers/62908.htmlie在tcl命令行中尝试“tclapp :: reset_tclstore”。
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 follow this AR http://www.xilinx.com/support/answers/62908.html ie try "tclapp::reset_tclstore" in the tcl command line.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
我试图这样做,但我尝试在TCL模式下启动vivado时得到相同的错误消息...我不知道任何其他方式能够运行该命令,我尝试复制该AR中提到的目录也
,它没有帮助。 以上来自于谷歌翻译 以下为原文 I tried to do that but I get the same error message when trying to start vivado in TCL mode... I don't know any other way to be able to run that command, and I tried copying the directories mentioned in that AR also, it did not help. |
我可以尝试任何想法吗?
我现在无法使用新版本的Vivado。 以上来自于谷歌翻译 以下为原文 Any ideas I can try? I'm unable to use Vivado at all at this point with the new version. |
它一直告诉我我缺少Visual Studio组件,但不会让我修复或卸载它们。
我还在.xlinx / xinstall目录中有一个名为“xic”的第二个文件,它显示以下内容: 2016-05-10 10:00:24,464 DEBUG:?:? - data dynamic_resource_bundle.properties,不存在2016-05-10 10:00:25,624 DEBUG:?:? - 开始听听2016-05-10 10:00:30,928 DEBUG:?:? - 警告,找不到加载通知历史文件:C: Users Don .Xilinx registry notifications.xml这可以是第一次xilinx SW安装.2016-05-10 10:00:31,983 DEBUG:?:? - 获取通知.2016-05-10 10:00:32,098 DEBUG:?:? - 从C: Xilinx .xinstall DocNav2016-05-10获取安装记录文件10:00:32,103 DEBUG:?:? - 不是全新安装。 升级安装。 找到安装数据文件,C: Xilinx .xinstall DocNav data instRecord.dat2016-05-10 10:00:32,303 DEBUG:?:? - 无法自动检测代理设置2016-05-10 10:00:32,323 DEBUG:?:? - XILINX_URL设置为http://www.xilinx.com/direct/swhelp2016-05-10 10:00:32,348 DEBUG:?:? - 将下载http://www.xilinx.com/direct/swhelp/installClientInfo.dat2016-05-10 10:00:32,348 DEBUG:?:? - 下载到C: Users Don AppData Local Temp 1462888832303 installClientInfo.dat2016-05-10 10:00:32,348 DEBUG:?:? - 文件不存在或文件不完整C: Users Don AppData Local Temp 1462888832303 installClientInfo.dat,删除并从头开始下载.2016-05-10 10:00:32,424 DEBUG:?:? - http下载:http://www.xilinx.com/direct/swhelp/installClientInfo.dat2016-05-10 10:00:32,859 DEBUG:?:? - 从C: Xilinx .xinstall Vivado_2016.12016-05-10获取安装记录文件10:00:32,859 DEBUG:?:? - 不是全新安装。 升级安装。 找到安装数据文件,C: Xilinx .xinstall Vivado_2016.1 data instRecord.dat2016-05-10 10:00:34,108 DEBUG:?:? - 警告,coudl未加载通知histroty文件:C: Users Don .Xilinx registry notifications.xml2016-05-10 10:00:35,161 DEBUG:?:? - 已成功下载http://www.xilinx.com/direct/swhelp/installClientInfo.dat。 下载了1629个字节,elapsedTime:0:0:0:02016-05-10 10:00:35,161信息:?:? - 验证互联网连接,可以连接到互联网.2016-05-10 10:00:35,161调试:?:? - 从以下位置加载安装客户端信息:C: Users Don AppData Local Temp 1462888832303 installClientInfo.dat2016-05-10 10:00:35,216 DEBUG:?:? - 通知网址:http://www.xilinx.com/direct/swhelp/notifications.xml2016-05-10 10:00:35,899 DEBUG:?:? - 获取通知.2016-05-10 10:00:35,904调试:?:? - 通知网址:http://www.xilinx.com/direct/swhelp/notifications.xml2016-05-10 11:00:36,058 DEBUG:?:? - 提取通知.2016-05-10 11:00:36,882 DEBUG:?:? - 通知URL:http://www.xilinx.com/direct/swhelp/notifications.xml 以上来自于谷歌翻译 以下为原文 It keeps telling me I'm missing Visual Studio components, but won't let me repair or uninstall them. I also have a second file in the .xlinx / xinstall dir called "xic" which shows the following : 2016-05-10 10:00:24,464 DEBUG:?:? - datadynamic_resource_bundle.properties, does not exist 2016-05-10 10:00:25,624 DEBUG:?:? - Starting to listen 2016-05-10 10:00:30,928 DEBUG:?:? - Warning, could not find load notification history file: C:UsersDon.Xilinxregistrynotifications.xml this can be first time xilinx SW installation. 2016-05-10 10:00:31,983 DEBUG:?:? - Fetching notifications.. 2016-05-10 10:00:32,098 DEBUG:?:? - Get the installation record file from C:Xilinx.xinstallDocNav 2016-05-10 10:00:32,103 DEBUG:?:? - Not a fresh installation. Upgrade installation. installation data file found, C:Xilinx.xinstallDocNavdatainstRecord.dat 2016-05-10 10:00:32,303 DEBUG:?:? - Could not auto detect proxy settings 2016-05-10 10:00:32,323 DEBUG:?:? - XILINX_URL is set to http://www.xilinx.com/direct/swhelp 2016-05-10 10:00:32,348 DEBUG:?:? - Will download http://www.xilinx.com/direct/swhelp/installClientInfo.dat 2016-05-10 10:00:32,348 DEBUG:?:? - Download to C:UsersDonAppDataLocalTemp1462888832303installClientInfo.dat 2016-05-10 10:00:32,348 DEBUG:?:? - File not exists or incomplete file C:UsersDonAppDataLocalTemp1462888832303installClientInfo.dat, deleting and starting download from scratch. 2016-05-10 10:00:32,424 DEBUG:?:? - http download: http://www.xilinx.com/direct/swhelp/installClientInfo.dat 2016-05-10 10:00:32,859 DEBUG:?:? - Get the installation record file from C:Xilinx.xinstallVivado_2016.1 2016-05-10 10:00:32,859 DEBUG:?:? - Not a fresh installation. Upgrade installation. installation data file found, C:Xilinx.xinstallVivado_2016.1datainstRecord.dat 2016-05-10 10:00:34,108 DEBUG:?:? - Warning, coudl not load notification histroty file: C:UsersDon.Xilinxregistrynotifications.xml 2016-05-10 10:00:35,161 DEBUG:?:? - Successfully downloaded http://www.xilinx.com/direct/swhelp/installClientInfo.dat. Downloaded 1629 bytes, elapsedTime: 0:0:0:0 2016-05-10 10:00:35,161 INFO :?:? - Internet connection validated, can connect to internet. 2016-05-10 10:00:35,161 DEBUG:?:? - Loading install client info from: C:UsersDonAppDataLocalTemp1462888832303installClientInfo.dat 2016-05-10 10:00:35,216 DEBUG:?:? - Notification URL: http://www.xilinx.com/direct/swhelp/notifications.xml 2016-05-10 10:00:35,899 DEBUG:?:? - Fetching notifications.. 2016-05-10 10:00:35,904 DEBUG:?:? - Notification URL: http://www.xilinx.com/direct/swhelp/notifications.xml 2016-05-10 11:00:36,058 DEBUG:?:? - Fetching notifications.. 2016-05-10 11:00:36,882 DEBUG:?:? - Notification URL: http://www.xilinx.com/direct/swhelp/notifications.xml |
凹凸不平,仍无法使用Vivado。
有什么方法可以帮助我吗? 即使它需要支付费用。 以上来自于谷歌翻译 以下为原文 Bump, still unable to use Vivado. Is there any way I can get help with this? Even if it requires paying for support. |
2458 浏览 7 评论
2851 浏览 4 评论
2313 浏览 9 评论
3399 浏览 0 评论
2492 浏览 15 评论
1966浏览 1评论
636浏览 1评论
494浏览 1评论
2041浏览 0评论
768浏览 0评论
GMT+8, 2025-1-24 00:43 , Processed in 1.136305 second(s), Total 49, Slave 44 queries .
