您好,我希望能够将当前调用堆栈打印到UART。有什么方法可以获得当前的字符串堆栈调用堆栈?例如:“主-gt;AuxiLARtiTY & GT;”如果不是,有没有办法在地址中打印调用堆栈?也就是说,不是一个字符串,而是一个函数地址数组?如果有,有一个工具,我可以得到这个数组的地址,并获得路径字符串?例如,假设主在0xAuxiLARTY在0xBiNeNER处于0xCI,当我在内部函数中并决定打印出调用堆栈时,UART调试器打印出[0xA,0xb,0xc],我可以把它输入到一个微芯片工具中,它给了我“主- &辅助函数-GT;内部”。谢谢!
以上来自于百度翻译 以下为原文 Hello, I want to be able to print the current call stack to UART. Is there any way I can get the current call stack in string format? for instance: "main->auxillarty->inner" if not, is there a way to print the call stack in addresses? that is, instead of a string, I get an array of function addresses? If yes, is there a tool where I can get this array of addresses and get a path string? for instance, suppose that: main is at 0xa auxillarty is at 0xb inner is at 0xc when I'm inside inner function and decide to print out the call stack, the UART debugger prints out [0xa, 0xb, 0xc] which I can feed into a Microchip tool that gives me "main->auxillarty->inner". Thanks! |
4个回答
嗨,抱歉晚回复(周末)芯片是PIC32 MZ2048 EFM064
以上来自于百度翻译 以下为原文 Hi, sorry for late reply (weekend) The chip is PIC32MZ2048EFM064 |
你发布在IDE论坛,所以我假设这是一个IDE问题。调试器的调用堆栈视图有什么问题?
以上来自于百度翻译 以下为原文 You posted in the IDE forum, so I am going to assume this is an IDE question. What is wrong with the debugger's call stack view? |
你好,安德烈斯!两件事:1。通常,IDE中出现的调用堆栈错误地空了——我在断点上刷新它,并且由于某种原因它是空的(当然是不正确的)2。如果出现错误,调试过程中不会出现错误,我希望能够将调用堆栈打印到冒犯函数中,比如Java。
以上来自于百度翻译 以下为原文 Hi andres! two things: 1. very often, the calls stack presented in the IDE is incorrectly empty - I refresh it on breakpoint, and it's empty for some reason (which is of course not correct) 2. in case of an error, not necesseraly during debug, I would like to be able to print the call stack to the offending function, like in java. |
5317 浏览 9 评论
2072 浏览 8 评论
1977 浏览 10 评论
3248 浏览 3 评论
2285 浏览 5 评论
831浏览 1评论
724浏览 1评论
670浏览 1评论
723浏览 0评论
619浏览 0评论
GMT+8, 2025-1-31 21:42 , Processed in 1.215995 second(s), Total 83, Slave 67 queries .
