我尝试用CY8CKIT-02用同样的软件对我的CY8C4248LQI-BL553和CY8C21334-24PVXI进行编程。我可以用PSoC编程器3.26和CY8C21334-24PVXI用3.13编程CY8C4248LQI-BL580。虽然我不能在同一台PC中使用同一个软件的不同版本,但我不能用相同的软件对这两个版本进行编程。有没有可能用PSoC程序员3.26编程CY8C21334-24PVXI或将这个产品的库(源文件)添加到软件中?因为我在3.26找不到设备家族。
以上来自于百度翻译 以下为原文 I am trying to program my CY8C4248LQI-BL583 and CY8C21334-24PVXI with CY8CKIT-002 with same software. I can program CY8C4248LQI-BL583 with PSoC Programmer 3.26 and CY8C21334-24PVXI with 3.13. While I cannot use same software's different versions in the same PC, I cannot program both of these with same software. Is there any possibility to program CY8C21334-24PVXI with PSoC Programmer 3.26 or adding libraries (source files) of this product to software? Because I could not find the device family on 3.26. |
要查看PSoC程序员3.26上的CY8C21334,请执行以下步骤:
在编程参数框中将Outlook自动设置为OFF 从程序员特性箱中选择协议ISSP -在设备族选择器中选择21x34 你会在设备选择器中找到CY8C21334-24PVXI。 以上来自于百度翻译 以下为原文 To get to view the CY8C21334 on PSoC Programmer 3.26, do the following steps: - Set AutoDetection to Off in the Programming Parameters box - Select Protocol ISSP from the Programmer Characteristics box - Select 21x34 in the Device Family selector - You will find CY8C21334-24PVXI in the Device selector. |
非常感谢。工作得很好!! 以上来自于百度翻译 以下为原文 Thank you so much. Worked pretty well !! |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
408浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-23 11:55 , Processed in 0.766740 second(s), Total 45, Slave 40 queries .
