扫一扫,分享给好友
大家好,
在将vivado 2016.1安装到d: xilinx时,发生以下错误: 提取存档D时遇到错误: Xilinx_Vivado_SDK_2016.1_0409_1 payload rdi_0076_2016.1_0409_1.xz可能的原因可能是:磁盘已满,您已超出磁盘配额,或目标目录太长。 我很确定d:/上有足够的空间,为什么目录太长了? 最好的祝福 向超 以上来自于谷歌翻译 以下为原文 hi all, While installing vivado 2016.1 to d:xilinx,the following error occured: Error was encountered while extracting archive D:Xilinx_Vivado_SDK_2016.1_0409_1payloadrdi_0076_2016.1_0409_1.xz The possible reasons can be: the disk is full, you've exceeded disk quota, or the destination directory is too long. I am pretty sure there is enough space on d:/, and why the directory is too long? best regards Xiang Chao |
嗨@南瓜,
请访问http://www.xilinx.com/support/answers/64982.html 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @pumpkin, Please go through http://www.xilinx.com/support/answers/64982.html Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨@南瓜,
你禁用了防病毒软件吗? 您也可以通过以下链接尝试Web安装程序:http://www.xilinx.com/support/download.html 还要检查您是否对要安装的文件夹具有正确的读写权限。 您可以尝试使用管理员权限。 此外,请确保下载文件的MD5总和与您从中下载的xilinx站点上提供的文件相匹配。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @pumpkin, Have you disabled antivirus? You can also try the web installer at this link: http://www.xilinx.com/support/download.html Also check if you have proper read-write permission on the folder where you are trying to install. You can try with Admin privileges. Also, make sure that the MD5 Sum of downloaded file matches the one provided on xilinx site where you downloaded it from. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1171浏览 1评论
585浏览 1评论
451浏览 1评论
2005浏览 0评论
729浏览 0评论
GMT+8, 2024-12-23 15:28 , Processed in 1.203228 second(s), Total 48, Slave 42 queries .
