我在Ubuntu 16.04上安装了Vivado 2016.1,并在安装时包含了SDK。
当我执行文件 - >启动SDK时,没有任何反应。 Tcl控制台显示: 信息:[Vivado 12-393]启动SDK ...信息:[Vivado 12-417]运行xsdk -workspace /media/wmat/passport/edt/edt_zcu102/edt_zcu102.sdk -hwspec/media / wmat / passport / edt / edt_zcu102 / edt_zcu102.sdk / edt_zcu102_wrapper.hdfINFO:[Vivado 12-3157]启动了SDK启动。 请检查控制台是否有任何其他消息。 但SDK无法启动。 我已将导出SWT_GTK3 = 0添加到.settings64-Software_Development_Kit_.sh并可以从命令行启动xsdk,但是如果从Vivado启动它会很好。 是否应该有../Vivado/2016.1/bin/xsdk可执行文件,或者SDK是否在Vivado目录之外单独安装? 如何让Vivado知道SDK的位置? 谢谢 法案 以上来自于谷歌翻译 以下为原文 I've installed Vivado 2016.1 on Ubuntu 16.04 and included the SDK at install time. When I do File -> Launch SDK, nothing happens. The Tcl Console shows: INFO: [Vivado 12-393] Launching SDK... INFO: [Vivado 12-417] Running xsdk -workspace /media/wmat/passport/edt/edt_zcu102/edt_zcu102.sdk -hwspec /media/wmat/passport/edt/edt_zcu102/edt_zcu102.sdk/edt_zcu102_wrapper.hdf INFO: [Vivado 12-3157] SDK launch initiated. Please check console for any further messages. But the SDK doesn't start. I have added export SWT_GTK3=0 to .settings64-Software_Development_Kit_.sh and can launch the xsdk from the command line, however it would be nice if it launched from Vivado. Should there be a ../Vivado/2016.1/bin/xsdk executable, or does the SDK get installed standalone outside of the Vivado directory? How do I get Vivado to know where the SDK is? Thanks Bill |
添加线
export SWT_GTK3 = 0 到/ opt /赛灵思/ SDK / 2016.1 / .settings64-Software_Development_Kit__SDK_.sh 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 add the line export SWT_GTK3=0 to /opt/Xilinx/SDK/2016.1/.settings64-Software_Development_Kit__SDK_.sh Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution.View solution in original post |
添加线
export SWT_GTK3 = 0 到/ opt /赛灵思/ SDK / 2016.1 / .settings64-Software_Development_Kit__SDK_.sh 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 add the line export SWT_GTK3=0 to /opt/Xilinx/SDK/2016.1/.settings64-Software_Development_Kit__SDK_.sh Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
2500 浏览 7 评论
2871 浏览 4 评论
2330 浏览 9 评论
3424 浏览 0 评论
2512 浏览 15 评论
2453浏览 1评论
660浏览 1评论
521浏览 1评论
801浏览 0评论
GMT+8, 2025-2-24 18:39 , Processed in 1.168441 second(s), Total 47, Slave 41 queries .
