您好,我使用的是“IC-CAP”软件,因此我可以访问我的MOS晶体管的VerilogA模型。
外部电压和流动电流由IC-CAP存储。 另外,我在每次调用我的模型时,在一个单独的文件中保存自己的计算值。 计算; cMOS-逆变器,nMOS-逆变器,cMOS环形振荡器; 效果很好。 但我希望能够迭代计算电流和电压。 但是,我找不到迭代计算。 每次调用我的模型时,都会计算出真实的电流和电压值。 如何使迭代可见? *非常感谢你* 以上来自于谷歌翻译 以下为原文 Hello, I use the software "IC-CAP" from, hereby I access to a VerilogA-model of my MOS-transistor. The external voltage and the flowing current is stored by IC-CAP. In addition, I save myself the calculated values at each call of my model, in a separate file. The calculation of; cMOS-inverter, nMOS-inverter, cMOS ring oscillator; works well. But I expect an iterative calculation of the currents and voltages. However, I can't find iterative calculations. At each call of my model, a true current and voltage value is calculated. How can I make the iterations visible? *Thank you very much* |
你好Fabian001我建议联系eesof_support@agilent.com讨论这个问题,并根据迭代结果澄清你在寻找什么。
(听起来你不仅仅想要最终的模拟结果,还有所有的中间结果?)如果你正在使用带有ICCAP的ADS / hpeesofsim模拟器来进行这些模拟,你可以考虑的一个选择是定义模型或 系统变量,如下所示:HPEESOFSIM_OPTIONS详细= 4然后在模拟调试器打开的情况下运行模拟,例如 工具/模拟调试器,您将看到有关迭代仿真结果的信息,这些信息发布到Simulation Debugger的Output窗口。 可以通过模拟调试器上的文件>保存输出文件保存该信息。 不确定这是否是您的想法,所以我建议您联系eesof_support@agilent.com并随时抄送我:else_schmidt@agilent.com。 最好的问候Else 以上来自于谷歌翻译 以下为原文 Hello Fabian001 I suggest to contact eesof_support@agilent.com to discuss this and clarify what you are looking for, in terms of the iterative results. (it sounds like you don't want just the final simulation result, but also all the intermediate results?) If you are using the ADS /hpeesofsim simulator with ICCAP for these simulations, one option you can consider, is to define a Model or System Variable, as follows: HPEESOFSIM_OPTIONS Verbose=4 And then run the simulation with the Simulation Debugger open, e.g. Tools/Simulation Debugger and you will see information about iterative simulation results posted to the Output window of the Simulation Debugger. That information can be saved via File > Save Output File off the Simulation Debugger. Not sure if that is what you had in mind, so I suggest to contact eesof_support@agilent.com and feel free to cc me: else_schmidt@agilent.com. Best regards Else |
1351 浏览 0 评论
2405 浏览 1 评论
2234 浏览 1 评论
2088 浏览 5 评论
2981 浏览 3 评论
1315浏览 1评论
794浏览 0评论
1101浏览 0评论
1351浏览 0评论
GMT+8, 2025-2-1 13:57 , Processed in 1.098570 second(s), Total 44, Slave 39 queries .
