扫一扫,分享给好友
Win7 x64
我已尝试过在线安装程序和完整安装程序。 按“安装”按钮时,图形工具(xsetup.exe)不执行任何操作 控制台工具(xsetup.bat)说: 版权所有(c)1986-2016 Xilinx,Inc。保留所有权利:日志文件位置 - C: Users serge .Xilinx xinstall xinstall_1468233396383.logINFO:Edition选择安装:Vivado HL WebPACKWARN:指定的值 在InstallOptions的配置文件中(启用WebTalk for SDK将使用情况统计信息发送到Xilinx)丢失或无效。警告:InstallOptions配置文件中指定的值(安装WinPCap for Ethernet Hardware Co-simulation)缺失或无效.WARN :在InstallOptions的配置文件中指定的值(启动配置管理器以将System Generator for DSP与matlab关联)缺失或无效。线程“main”中的异常java.util.NoSuchElementException:在java.util.Scanner中找不到行。 nextLine(Scanner.java:1540)位于nt(未知来源)位于ntt(未知来源)位于caj(未知来源)处于caa(未知来源)位于cha(未知来源)位于cha.xilinx.installer处(未知来源) .api.InstallerLauncher.mai n(未知来源) 看起来图形工具里面有相同的例外,但是复制起来比较困难。 附上我的一个尝试的日志 xinstall_1468226200904.log 22 KB 以上来自于谷歌翻译 以下为原文 Win7 x64 I have tried both online installer and full installer. Graphical tool (xsetup.exe) does nothing when I press Install button Console tool (xsetup.bat) says: Copyright (c) 1986-2016 Xilinx, Inc. All rights reserved. INFO : Log file location - C:Usersserge.Xilinxxinstallxinstall_1468233396383.log INFO : Edition Selected to be installed: Vivado HL WebPACK WARN : The value specified in the configuration file for InstallOptions (Enable WebTalk for SDK to send usage statistics to Xilinx) is missing or invalid. WARN : The value specified in the configuration file for InstallOptions (Install WinPCap for Ethernet Hardware Co-simulation) is missing or invalid. WARN : The value specified in the configuration file for InstallOptions (Launch configuration manager to associate System Generator for DSP with MATLAB) is missing or invalid. Exception in thread "main" java.util.NoSuchElementException: No line found at java.util.Scanner.nextLine(Scanner.java:1540) at n.t.a(Unknown Source) at n.t.b(Unknown Source) at n.t.t(Unknown Source) at c.a.j(Unknown Source) at c.a.a(Unknown Source) at c.h.a(Unknown Source) at com.xilinx.installer.api.InstallerLauncher.main(Unknown Source) It looks like graphical tool have the same exception inside, but it is harder to copy. Log of one of my tries is attached xinstall_1468226200904.log 22 KB |
6个回答
你好@ spyptev
您可以卸载Microsoft Visual C ++ 2013 Redistributable和Microsoft Visual C ++ 2015 Redistributables并尝试安装Vivado 2016.2吗? 如果这没有帮助,请在此处共享最新的安装日志文件。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @spyptev Can you uninstall Microsoft Visual C++ 2013 Redistributable and Microsoft Visual C++ 2015 Redistributables and try installing Vivado 2016.2? If this doesn't help, share the latest install log file here. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
嗨@spyptev
我没有在日志文件中看到任何错误消息。 尝试以下答案记录中提到的调试步骤:http://www.xilinx.com/support/answers/60118.html 如果没有任何步骤有帮助,请尝试以批处理模式安装Vivado工具。 请参阅第页。 以下用户指南中的22:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug973-vivado-release-notes-install-license.pdf 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @spyptev I don't see any error messages in the log file. Try the debug steps mentioned in the following answer record: http://www.xilinx.com/support/answers/60118.html If none of the steps help, try installing the Vivado tool in batch mode. See the page no. 22 in the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug973-vivado-release-notes-install-license.pdf Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay,
我无法在任何模式下安装Vivado。 在我的第一条消息中,您可以看到批处理模式安装的控制台日志(不在日志文件中,而是直接在消息体中)。 你可以在日志中看到错误。 类似的错误在其他模式中,它只是更难复制。 据我所知,主要问题是在日志的以下行: 线程“main”中的异常java.util.NoSuchElementException:在java.util.Scanner.nextLine中找不到行(Scanner.java:1540) 当有人读取下一行输入文件(或stdin)并忘记检查该行是否存在时,通常是java bug。 但我不认为Xilinx java程序员真的写过这样的学生的bug。 以上来自于谷歌翻译 以下为原文 Hi Vinay, I can not install Vivado in any mode. In my first message you can see console log of batch mode install (not in log file but in message body directly). And you can see error in the log. Similar error is in other modes, it is only harder to copy it. As far as I understand main problem is in the following line of the log: Exception in thread "main" java.util.NoSuchElementException: No line found at java.util.Scanner.nextLine(Scanner.java:1540) it is usual java bug when somebody read next line of input file (or stdin) and forget to check before if the line exists. But I do not think that Xilinx java programmer really wrote such student's bug. |
你好@ spyptev
你的机器上安装了哪个版本的java? 您的计算机上还安装了哪个版本的Microsoft Visual C ++可再发行组件? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @spyptev Which version of java installed on your machine? Also which version of Microsoft Visual C++ redistributables are installed on your machine? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
这是来自Java控制面板的信息。
看起来主Java版本是1.8.0_91 1.8 1.8.0_91 http://java.sun.com/products/autodl/j2se C: Program Files Java jre1.8.0_91 bin javaw.exe 真正 1.8 1.8.0_66 http://java.sun.com/products/autodl/j2se C:赛灵思西昌 TPS Win64的 JRE BIN javaw.exe的 真正 1.8 1.8.0_66 http://java.sun.com/products/autodl/j2se C:赛灵思 Vivado_HLS 2016.1 TPS Win64的 JRE BIN javaw.exe的 真正 1.8 1.8.0_66 http://java.sun.com/products/autodl/j2se C:赛灵思 Vivado 2016.1 TPS Win64的 JRE BIN javaw.exe的 真正 1.8 1.8.0_66 http://java.sun.com/products/autodl/j2se C:赛灵思下载 Vivado_2016.2 TPS Win64的 JRE BIN javaw.exe的 真正 1.8 1.8.0_66 http://java.sun.com/products/autodl/j2se C:赛灵思下载 Vivado_2016.1 TPS Win64的 JRE BIN javaw.exe的 真正 1.8 1.8.0_66 http://java.sun.com/products/autodl/j2se C:赛灵思 .xinstall 西昌 TPS Win64的 JRE BIN javaw.exe的 真正 1.8 1.8.0_66 http://java.sun.com/products/autodl/j2se C:赛灵思 .xinstall Vivado_2016.1 TPS Win64的 JRE BIN javaw.exe的 真正 1.8 1.8.0_66 http://java.sun.com/products/autodl/j2se C:赛灵思 .xinstall DocNav TPS Win64的 JRE BIN javaw.exe的 真正 Microsoft Visual C ++ 2005 Redistributable - 8.0.61000 Microsoft Visual C ++ 2008 Redistributable - 9.0.30729.6161 Microsoft Visual C ++ 2010 Redistributable - 10.0.40219 Microsoft Visual C ++ 2012 Redistributable - 11.0.61030 Microsoft Visual C ++ 2013 Redistributable - 12.0.21005 Microsoft Visual C ++ 2015 Redistributable - - 14.0.23026 谢谢, 哔叽 以上来自于谷歌翻译 以下为原文 This is information from Java control panel. It looks like that main Java version is 1.8.0_91
Microsoft Visual C++ 2005 Redistributable - 8.0.61000 Microsoft Visual C++ 2008 Redistributable - 9.0.30729.6161 Microsoft Visual C++ 2010 Redistributable - 10.0.40219 Microsoft Visual C++ 2012 Redistributable - 11.0.61030 Microsoft Visual C++ 2013 Redistributable - 12.0.21005 Microsoft Visual C++ 2015 Redistributable - 14.0.23026 Thanks, Serge |
你好@ spyptev
您可以卸载Microsoft Visual C ++ 2013 Redistributable和Microsoft Visual C ++ 2015 Redistributables并尝试安装Vivado 2016.2吗? 如果这没有帮助,请在此处共享最新的安装日志文件。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @spyptev Can you uninstall Microsoft Visual C++ 2013 Redistributable and Microsoft Visual C++ 2015 Redistributables and try installing Vivado 2016.2? If this doesn't help, share the latest install log file here. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1172浏览 1评论
585浏览 1评论
451浏览 1评论
2005浏览 0评论
729浏览 0评论
GMT+8, 2024-12-23 15:44 , Processed in 1.146695 second(s), Total 56, Slave 50 queries .
