嗨,大家好,
我确实打开了一个网络案例,但Xilinx拒绝了它,因为他们说我的公司名称无效,现在不会让我创建一个新的网络案例。 Qualitysupport! 也许这里有人可以帮助我: 我在这里有一个Spartan 3E入门套件并且已经下载了Webpack ISE 14.7.XPS抱怨在启动时没有许可证并且hen试图生成比特流失败:错误:EDK - 信息:安全:71 - 如果部分'xc3s500e的许可证 '可用,它可以使用'XPS_TDP'代替'XPS'.INFO:安全性:61 - XILINXD_LICENSE_FILE环境变量不是set.INFO:Security:63 - LM_LICENSE_FILE环境变量不是set.INFO:Security: 68 - 有关获取许可证的更多信息或帮助,请运行Xilinx许可证配置管理器(xlcm或“管理Xilinx许可证”)。信息:安全:68a - 用户是andrewcapon,主机上是ANDREWCAPONEC68。警告:安全:9b - 否 'XPS'功能版本2013.10可用于part'xc3s500e'.ERROR:安全:12 - 没有'xc3s500e'功能版本2013.10可用(-5),因此'XPS_TDP'可能不会被使用。没有这样的功能存在。特点: XPSDoes Webpack不支持Spartan 3E入门套件上的EDK?网页http://www.xilinx .com / products / boards-and-kits / HW-SPAR3E-SK-US-G.ht表示支持EDK:“ISE®WebPACK™软件,ISE Foundation™软件评估和嵌入式开发套件(EDK) “谢谢你的帮助。所有最好的安迪 以上来自于谷歌翻译 以下为原文 Hi Guys, I did open a web case on this but Xilinx rejected it as they said my company name was invalid and now won't let me create a new web case. Quality support! Maybe someone here can help me: I have a Spartan 3E starter kit here and have downloaded the Webpack ISE 14.7. XPS complains on startup about not having a license and hen trying to generate bitstreams fails: ERROR:EDK - INFO:Security:71 - If a license for part 'xc3s500e' is available, it will be possible to use 'XPS_TDP' instead of 'XPS'. INFO:Security:61 - The XILINXD_LICENSE_FILE environment variable is not set. INFO:Security:63 - The LM_LICENSE_FILE environment variable is not set. INFO:Security:68 - For more information or for assistance in obtaining a license, please run the Xilinx License Configuration Manager (xlcm or "Manage Xilinx Licenses".) INFO:Security:68a - user is andrewcapon, on host ANDREWCAPONEC68. WARNING:Security:9b - No 'XPS' feature version 2013.10 was available for part 'xc3s500e'. ERROR:Security:12 - No 'xc3s500e' feature version 2013.10 was available (-5), so 'XPS_TDP' may not be used. No such feature exists. Feature: XPS Does Webpack not support EDK on the Spartan 3E starter kit? The webpage http://www.xilinx.com/products/b ... -SPAR3E-SK-US-G.htm seems to show that EDK is supported: "ISE® WebPACK™ software, ISE Foundation™ software evaluation, and the Embedded Development Kit (EDK)" Thanks for any help. All the best Andy |
10个回答
嗨,
使用Webpack许可证,您只能通过定位以下设备XC7Z010,XC7Z020和XC7Z030来访问XPS。 你可以附上你的xinfo和许可证文件进行调查。 您可以从开始生成xinfo - >所有程序 - > Xilinx ISE设计套件 - >附件 - > Xinfo系统检查器。 以上来自于谷歌翻译 以下为原文 Hi, With Webpack license, you can access XPS by targeting the following devices XC7Z010, XC7Z020 and XC7Z030 only. Can you attach your xinfo and license file for investigation. You can generate xinfo from start --> All Programs --> Xilinx ISE Design Suite --> Accessories --> Xinfo System Checker. |
嗨,转到许可委员会。
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Moving to licensing board.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨Manusha,
感谢超级快速的回复,我想这就是为什么它不适用于这款Spartan 3E主板,但是我使用的是7020主板。 祝一切顺利 安迪 以上来自于谷歌翻译 以下为原文 Hi Manusha, Thanks for the super quick reply, I guess that is why it doesn't work with this Spartan 3E board but does with some 7020 boards I have. All the best Andy |
嗨,安迪,
是的,你是对的。你可以通过仅针对XC7Z010,XC7Z020和XC7Z030设备访问带有webpack许可证的XPS。 您可以在webpack license PACKAGE部分中进行交叉检查。 以上来自于谷歌翻译 以下为原文 Hi Andy, Yes you are correct.You can access XPS with webpack license by targeting XC7Z010, XC7Z020 and XC7Z030 devices only. You can cross-check it in your webpack licenses PACKAGE section. |
嗨Manusha,
Thnaks的信息。 很抱歉,如果这是一个愚蠢的问题,但我如何创建无法访问XPS的PLB MicroBlaze外围设备? 有没有办法在PlanAhead或ISE中这样做? 谢谢你的帮助 安迪 以上来自于谷歌翻译 以下为原文 Hi Manusha, Thnaks for the info. Sorry if this is a stupid question but how would I go about creating PLB MicroBlaze peripherals with no access to XPS? Is there a way of doing this in PlanAhead or ISE? Thanks for any help Andy |
嗨,安迪,
不,您必须使用XPS来创建PLB微纤维外围设备。 谢谢。 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Andy, No, you have to use XPS to create PLB microblaze peripherals. Thanks. Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay,
非常感谢您的信息。 也许应该更新网页:http://www.xilinx.com/products/boards-and-kits/HW-SPAR3E-SK-US-G.htm,因为它表明在Spartan 3e启动器上通过webpack支持EDK 套件显然不是这种情况。 这会浪费我一些浪费在董事会上的钱! 干杯 安迪 以上来自于谷歌翻译 以下为原文 Hi Vinay, Thanks very much for the info. Maybe the webpage at http://www.xilinx.com/products/boards-and-kits/HW-SPAR3E-SK-US-G.htm should be updated as it states that the EDK is supported via webpack on the Spartan 3e starter kit where this is obviously not the case. It would have saved me some money on a wasted board! Cheers Andy |
嗨Andy,该链接讲述了ISE 8.1i版本的工具。
根据链接,您将获得8.1i版本的“ISE®WebPACK™软件,ISE Foundation™软件评估和嵌入式开发套件(EDK)”。 你没有收到带有套件的ISE版本8.1i的CD / DVD吗? 谢谢,维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Andy, The link speaks about ISE 8.1i version of tools. As per the link, you will get " ISE® WebPACK™ software, ISE Foundation™ software evaluation, and the Embedded Development Kit (EDK)" of 8.1i version. Didnt you receive CD/DVD of the ISE version 8.1i with the kit? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay,
谢谢回复。 不,我没有使用该套件获得CD / DVD。 它于9月12日从farnell.co.uk订购,包括电路板,PSU和USB引线。 如果我安装8.1i,我可以使用EDK吗? 非常感谢 安迪 以上来自于谷歌翻译 以下为原文 Hi Vinay, Thanks for the reply. No I did not get a CD/DVD with the kit. It was ordered from farnell.co.uk on the 12th September, the box included the board, a PSU and a u*** lead only. If I install 8.1i will I be able to use the EDK then? Many Thanks Andy |
嗨,我为恢复这样一个旧线程而道歉,但我处于类似情况,这篇文章似乎从未解决过,只是放弃了。
我有一些最新的基于Xilinx的主板:VC707,Virtex II Pro。 这些很棒,我有完整的许可证。 然而,这些都很昂贵,并且在很多场合我发现自己希望尝试使用我的旧主板,例如我的Atlys(Spartan 6),Nexys 2(Spartan 3E),甚至是旧的Spartan入门套件和旧的样品包。 对于快速测试我的一小部分设计非常有用。 然而,我的大多数设计现在都使用uBlaze内核,当我尝试使用ISE 14.7时遇到了问题,我在本文开头就指出了相同的错误。 因此,似乎ISE Webpack的EDK不支持Spartan 6和Spartan 3部分。 因此,我可以有效地使用它们吗? ISE现在是EOL,因此购买完整许可证没有多大意义(不知道它是否仍然是4个销售)。 有没有办法做到这一点,还是我应该联系Xilinx销售部门购买像ISE这样的EOL产品的完整许可证? 谢谢 即 以上来自于谷歌翻译 以下为原文 Hi, I apologize for reviving such an old thread, but I'm in similar situation and this post seems like was never solved, just abandoned. I have some of the latest Xilinx based boards: VC707, Virtex II Pro. These are great and I have the full licenses. However these are expensive and in many occasions I find myself desiring to try my design using some of my old boards such as my Atlys (Spartan 6), Nexys 2 (Spartan 3E), even the old Spartan Starter Kit and the older Sample Pack have been useful to test out small portions of my designs quickly. However most of my designs are now using uBlaze cores and here comes the problem when I try to use ISE 14.7 and I get the same error indicated at the begining of this post. So, it seems ISE Webpack's EDK doesn't support the Spartan 6 and Spartan 3 parts. Hence what can I effectively do to use them? ISE is now EOL, so it doesn't make much sense to buy a full license (don't know if it is even still 4 sale). Is there a way to do it or should I just contact Xilinx sales to purchase a full license for an EOL product like ISE? Thanks e. |
2308 浏览 7 评论
2719 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2355 浏览 15 评论
633浏览 1评论
1685浏览 1评论
444浏览 1评论
203浏览 1评论
653浏览 0评论
GMT+8, 2024-9-22 01:46 , Processed in 1.304633 second(s), Total 63, Slave 58 queries .
