扫一扫,分享给好友
我需要通过vivado 2016.2编写位文件和ltx文件。
尝试仅安装hw_server:http://www.xilinx.com/support/download.html。 某些目录是在C:/ Xilinx下创建的,但是如何打开hw管理器 以上来自于谷歌翻译 以下为原文 I need to program bit file and ltx files through vivado 2016.2. Tried installing only the hw_server at https://www.xilinx.com/support/download.html. Some directory is created under C:/Xilinx but how to open the hw manager |
4个回答
@ hulk789No,您已经安装了硬件服务器而不是硬件管理器。
您必须安装vivado实验室工具。 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @hulk789 No, You have installed hardware server not the hardware manager. You have to install vivado lab tools. -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
嗨@ hulk789,
如果您在本地计算机上连接板,则可以从Vivado打开硬件管理器并加载.bit和.ltx文件。 如果要远程连接板,则在连接板的机器上运行硬件服务器。 它将显示端口号以及服务器名称 在客户端打开硬件管理器并使用远程服务器,然后继续。 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @hulk789, If you are connecting board in local machine then you can open hardware manager from Vivado and the load the .bit and .ltx file. If you are connecting board remotely then Run hardware server on the machine to which board is connected. It will display the port number along with server name In the client side open hardware manager and use remote server and then proceed. Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,这是我已经安装的。
是否会安装硬件管理器。 我想从本地机器编程。 vivado 2016.2要求安装大小约为32GB。 我没有那么多空间。 以上来自于谷歌翻译 以下为原文 Hi this is what i have installed. Will Hardware manager be installed with this. I want to program from local machine. vivado 2016.2 requires installation size of around 32GB. I do not have that much space free. |
您必须安装vivado实验室工具。 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @hulk789 No, You have installed hardware server not the hardware manager. You have to install vivado lab tools. -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
2458 浏览 7 评论
2851 浏览 4 评论
2313 浏览 9 评论
3399 浏览 0 评论
2492 浏览 15 评论
1977浏览 1评论
636浏览 1评论
494浏览 1评论
2041浏览 0评论
768浏览 0评论
GMT+8, 2025-1-24 11:28 , Processed in 1.075943 second(s), Total 47, Slave 42 queries .
