我使用STM32单片机与ADIS16488通过SPI通信,连接图和官方手册一样,其中23引脚实时时钟电源和9引脚数据就绪我没有接,因为我不需要用外部时钟和数据就绪信号,我是在初始化各个引脚后,先去用SPI读取传感器的PROD_ID,按照手册上写的,如果读取为0X4068,则代表SPI协议读取正确。 问题在于,我同样的连线,有时传感器初始化不成功,表现为读取PROD_ID为0xFFFF或0x0,有时传感器初始化可以成功,读取PROD_ID为0x4068。 大多情况是如果几天不用,再次使用时,不能正确读取PROD_ID,过几个小时,偶然间就可以正确读取了,之后就一直正确的,不管断电重启还是怎样。但如果间隔一两天不使用就会读取错误。下面是我ADIS16488的SPI初始化程序 void SPI_FLASH_Init(void){ SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Enable SPI1 and GPIO clocks */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); /*!< SPI_FLASH_SPI Periph clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); /*!< Configure SPI_FLASH_SPI pins: SCK MISO MOSI*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 |GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Deselect the FLASH: Chip Select high */ SPI_FLASH_CS_HIGH(); /* SPI1 configuration */ // W25X16: data input on the DIO pin is sampled on the rising edge of the CLK. // Data on the DO and DIO pins are clocked out on the falling edge of CLK. SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_Init(SPI1, &SPI_InitStructure); /* Enable SPI1 */ SPI_Cmd(SPI1, ENABLE);} 读取PROD_ID的程序 uint16_t SPI_FLASH_ReadDeviceID(void){ u16 Temp = 0; /* Select the FLASH: Chip Select low */ SPI_FLASH_CS_LOW(); /* Send "PROD_ID " instruction */ SPI_FLASH_SendTwoByte(0X7E00); /* Read two bytes from the FLASH */ Temp = SPI_FLASH_SendTwoByte(0xFFFF); /* Deselect the FLASH: Chip Select high */ SPI_FLASH_CS_HIGH(); return Temp;} main程序 USART1_Config();/* ADIS spi初始化 */SPI_FLASH_Init();/* Get SPI Flash Device ID */PROD_ID = SPI_FLASH_ReadDeviceID();if (PROD_ID != 0x4068) { printf("rn PROD_ID = 0x%X ", PROD_ID); printf("rn ADIS16488初始化失败"); while(PROD_ID != 0x4068) { PROD_ID = SPI_FLASH_ReadDeviceID(); printf("rn PROD_ID = 0x%X ", PROD_ID); } }printf("rn PROD_ID = 0x%X ", PROD_ID);printf("rn ADIS16488初始化成功"); 在读取正确的时候,6号CS片选端的电压为3.10V或更低到2.9V,读取错误的时候,片选端电压为3.28V,和电源电压一样。 这个问题很奇怪,一直在困扰我,我想问问是不是某些细节被我疏忽了。 |
您好。请使用示波器抓取读取product ID的时序波形,看正确通讯和错误通讯是否有什么情况区别。请在靠近ADIS16488的位置测量。可以把时序波形传上来看一下
2281个成员聚集在这个小组
加入小组998 浏览 2 评论
1392 浏览 2 评论
1940 浏览 1 评论
4273 浏览 2 评论
9065 浏览 1 评论
1538浏览 3评论
1698浏览 2评论
999浏览 2评论
1675浏览 2评论
1392浏览 2评论
GMT+8, 2024-12-25 23:11 , Processed in 0.768626 second(s), Total 44, Slave 39 queries .
