Uint32 ulValue;
long lValue; // 执行下面的语句之后 ulValude = 0x0FFF 0FFF, 而不是0x0FFF ulValue = AdcResult.ADCRESULT8; // AdcResult.ADCRESULT8的值为0x0FFF; // 执行下面的语句之后lValue = 0 lValue = AdcResult.ADCRESULT8; // AdcResult.ADCRESULT8的值为0x0FFF; 难道28069的CLA不支持数据类型转换吗?或者需要做什么配置? |
1 个讨论
Uint32 ulValue;
long lValue; // 执行下面的语句之后 ulValude = 0x0FFF 0FFF, 而不是0x0FFF ulValue = AdcResult.ADCRESULT8; // AdcResult.ADCRESULT8的值为0x0FFF; // 执行下面的语句之后lValue = 0 lValue = AdcResult.ADCRESULT8; // AdcResult.ADCRESULT8的值为0x0FFF; 难道28069的CLA不支持数据类型转换吗?或者需要做什么配置? Eric: CLA architecture is designed for 32-bit data types 16-bit computations incur overhead for sign-extension Primarily used for reading and writing to 16-bit peripheral registers TYPE CPU CLA char, short 16 bit 16 bit int 16 bit 32 bit long 32 bit 32 bit long long 64 bit 32 bit float, double 32 bit 32 bit long double 64 bit 32 bit pointers 32 bit 16 bit 加强制类型转换: xDelay[0] = (float32)AdcResult.ADCRESULT0; - ERIC |
341 浏览 1 评论
539 浏览 2 评论
781 浏览 3 评论
655 浏览 1 评论
1138 浏览 1 评论
69浏览 29评论
217浏览 23评论
257浏览 20评论
205浏览 14评论
65浏览 13评论
GMT+8, 2024-12-25 13:32 , Processed in 1.172500 second(s), Total 62, Slave 50 queries .
