嗨,我几个月前一直在使用webpack许可证运行ISE 14.7,现在我的许可证已经过期了。
我正在尝试获得新的许可证,但根据产品许可证,ISE 14.7 webpack似乎没有任何东西? 想知道是否有人可以提供帮助,因为网站上的欧洲电话热线电话号码也是错误的(0800-5152-5152这实际上是一家英国空中公司)! 谢谢 以上来自于谷歌翻译 以下为原文 Hi, I have been running ISE 14.7 with a webpack license up until a few months ago and now my license has expired. I'm trying to get a new license but under product licensing there does not seem to be anything for ISE 14.7 webpack? Wondered if anyone could help as the european phone helpline number on the website is also wrong (0800-5152-5152 this is actually a UK aerial company)! Thanks |
5个回答
你好,
您可以在下面查看AR,其中包含有关WebPack licensehttp://www.xilinx.com/support/answers/40086.html的详细信息。 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, You can check below AR which has details about WebPack license http://www.xilinx.com/support/answers/40086.html Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,Ashish,
如果我查看XLCM,有许多有效的许可证,但没有一个是ISE Webpack。 有什么想法吗? 以上来自于谷歌翻译 以下为原文 Hi Ashish, If I look in the XLCM there are lots of valid licenses, but none are ISE Webpack. Any Thoughts? |
你好@ williamsf2,
您是否在Xilinx.com上的“许可证创建”区域中选中了“管理许可”选项卡? 如果您已经生成了许可证,那么它应该存在于此处。 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @williamsf2, Did you check "Manage License" tab in the License Creation area on Xilinx.com? If you have already generated the license, it should be present here. Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,管理许可证标签只显示,PetaLinux工具许可证和Vivado HLS评估许可证?
不确定PetaLinux是什么,但不久前可能已经尝试过Vivado。 在“创建新许可证”选项卡下,它有四个灰色的“基于激活的许可证”,一个是Vivado webpack许可证,(状态/当前,订阅结束日期/无)但是没有ISE webpack许可证? ISE是我所需要的,因为这是我所有的工作设计所使用的。 还有什么想法吗? 谢谢 以上来自于谷歌翻译 以下为原文 Hi, Manage licences tab just shows, PetaLinux Tools license and Vivado HLS Evaluation license? Not sure what PetaLinux is, but might have tried Vivado a while ago. Under the "create new license" tab it does have four greyed out "Activation based licenses" and one is a Vivado webpack license, (with status/current, subscription end date/ none) but there is no ISE webpack license? ISE is what I need as that is what all my working designs use. Any more ideas? Thanks |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
443浏览 1评论
201浏览 1评论
653浏览 0评论
GMT+8, 2024-9-21 11:10 , Processed in 1.178354 second(s), Total 86, Slave 70 queries .
