扫一扫,分享给好友
你好:
最近我决定测试基于Vivado 14.4的系统生成器,我的操作系统是64位WIN7,但我的matlab是32位。 根据系统生成器的要求,我必须用Matlab将32位vivado安装到intergarte。 但似乎32位Vivado不支持64位操作系统,是吗? 我下载了Vivado 14.4的完整产品安装,发现不包括32位版本。 在Vivado有32位和64位的分区吗? 我记得他们在ISE一起。 以上来自于谷歌翻译 以下为原文 Hello: recently I decide to test System generator based on Vivado 14.4, My OS is 64 bit WIN7, but my Matlab is 32 bit. according to requirement of System generator,I have to install 32 bit vivado to intergarte with Matlab. but it seems 32 bit Vivado doesn't support 64 bit OS, is that right? I downloaded the full product installation of Vivado 14.4 and found the 32bit version is not included. are 32bit and 64bit separtated in Vivado? I remember they are together in ISE. |
你好@ tangseng79,
是的,您的理解是正确的.32位安装程序仅适用于32位操作系统,并且在64位计算机上不受支持。 Vivado 2014.4中应该有32位安装程序。 从Vivado 2015.1开始,已删除32位操作系统和应用程序支持。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @tangseng79, Yes, your understanding is right. 32-bit installer will only work on 32-bit operating systems and is not supported on 64-bit machines. 32 bit installer should be present in Vivado 2014.4. Beginning with Vivado 2015.1, 32-bit OS and application support has been removed. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
2308 浏览 7 评论
2719 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2355 浏览 15 评论
633浏览 1评论
1685浏览 1评论
444浏览 1评论
203浏览 1评论
653浏览 0评论
GMT+8, 2024-9-22 06:39 , Processed in 0.904303 second(s), Total 43, Slave 38 queries .
