嗨,我尝试在端口1执行源校准,功率= -6dBm(容差0.05dBm),N5245A PNA-x使用E4419B功率计和8487A功率传感器通过85133-60016戈尔电缆连接。
它通过18GHz直到50GHz并且在几乎50Ghz时失败,显示出不同级别的source1输出1.如果我们跳过gore电缆并直接将功率传感器固定到PNA-X端口1,它通过了呼叫。当我尝试执行源cal时 在端口3上使用相同的设置,它通过了cal。 它可能导致50GHz失败的原因是什么? 以上来自于谷歌翻译 以下为原文 Hi, i tried performing source cal at port 1, power = -6dBm(tolerance 0.05dBm) with N5245A PNA-x connecting thru 85133-60016 gore cable using E4419B power meter and 8487A power sensor. It cal thru 18GHz till 50GHz and it fails cal at almost 50Ghz showing unlevel source1 out 1. it passed the call if we skip the gore cable and directly fix the power sensor to the PNA-X port 1. when i tried to perform source cal with the same setting on port 3, it passed the cal. what could be the possible reason for it to fail at 50GHz? |
预设PNA时,设置的输出功率是多少?
这是PNA在整个频率范围内的最大指定功率。 对于这个PNA,它可能约为-15dBm。 您正在使用-6dBm *和*,而您正在使用电缆。 我很惊讶它甚至工作得很好。 尝试使用较低的功率,如-10或-15dBm。 它应该工作。 以上来自于谷歌翻译 以下为原文 When you preset the PNA, what is the output power set to? That is the max specified power of the PNA across the entire frequency range. For this PNA it is probably about -15dBm. You are requesting -6dBm *and* on top of that you are using a cable. I am surprised it is even working that well. Try using a lower power such as -10 or -15dBm. It should then work. |
正如jvall所说,功率降至47 GHz以上。 取决于选项,423由于额外的电缆损耗而远低于400。 端口3通常比端口1具有更多的功率,因为端口1至少有一个更多的switich,但规格是相同的。用波斯语的意大利语融合...编辑:Dr_joel于2014年2月21日10: 05 AM 以上来自于谷歌翻译 以下为原文 As jvall says, the power degrades above 47 GHz. Depends upon option, with 423 having much lower than 400 because of extra cable loss. Port 3 typically has a little more power than Port 1, due to port 1 going thrugh at least one more switich, but specifications are the same. Confused an Italian with a Persian...Edited by: Dr_joel on Feb 21, 2014 10:05 AM |
1033 浏览 0 评论
2278 浏览 1 评论
2065 浏览 1 评论
1937 浏览 5 评论
2808 浏览 3 评论
799浏览 1评论
585浏览 0评论
681浏览 0评论
2464浏览 0评论
1521浏览 0评论
GMT+8, 2024-9-21 03:18 , Processed in 1.370340 second(s), Total 78, Slave 62 queries .
