我在我的win 8.1计算机上加载了ISE 14.7但它没有用。
我退回了许可证并在旧的Tosiba XP机器上安装了Web包。 我无法生成新许可证或转移旧许可证。 帮帮我 以上来自于谷歌翻译 以下为原文 I loaded ISE 14.7 on my win 8.1 computer and it did not work. I returned the license and installed the web pack on an old Tosiba XP machine. I cannot generate a new license or transfer the old one. HELP |
查看本指南
UG631 - Xilinx ISE设计套件14:发行说明,安装和许可(ver14.7,1845KB)[PDF] 请联系客户支持团队。 他们会将您的许可证添加回您的帐户。 您需要重新初始化可信存储,并在客户支持团队将其添加回您的帐户后再次生成许可。 在Xilinx网站上的youraccount上试用onxilinx许可页面,然后转到yourlicensingpage,在那里您可以使用manage license选项卡下的说明选择该计算机上其他磁盘驱动器的序列号, 在这里查看一些常见问题解答 http://www.xilinx.com/tools/faq.htm 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 check this guide UG631 - Xilinx ISE Design Suite 14: Release Notes, Installation, and Licensing ( ver14.7, 1845 KB ) [size=-2][PDF] Please contact Customer support team. They will add your license back to your account. You need to reinitialize your trusted storage and generate the license again once the customer support team adds it back to your account. try on xilinx licensing page on your account on the Xilinx site and go to your licensing page where you can used the instructions under the manage license tab to select the serial number of the other disk drive on that computer, check the some FAQ here as well http://www.xilinx.com/tools/faq.htm Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
你好@ businessend
按照以下答案记录中提到的步骤重新托管许可证文件:http://www.xilinx.com/support/answers/36136.html 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @businessend Follow the steps mentioned in the following answer record to re-host the license file: http://www.xilinx.com/support/answers/36136.html Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2458 浏览 7 评论
2851 浏览 4 评论
2313 浏览 9 评论
3399 浏览 0 评论
2492 浏览 15 评论
1960浏览 1评论
636浏览 1评论
494浏览 1评论
2041浏览 0评论
768浏览 0评论
GMT+8, 2025-1-23 11:55 , Processed in 1.092608 second(s), Total 45, Slave 40 queries .
