扫一扫,分享给好友
你好,
我已经成功地在我的Windows PC上安装了Vivado WebPack许可证。 我希望不要在另一台PC上安装Vivado,但许可管理器不允许我创建第二个许可证,我总是偶然发现以下错误: [Common 17-345]找不到功能'Synthesis'和/或设备'xc7a35t'的有效许可证。 请运行Vivado许可证管理器以获取有关确定哪些功能和设备已获得系统许可的帮助。解决方案:在Vivado许可证管理器中检查许可证的状态。 对于调试帮助,请搜索Xilinx支持“许可常见问题解答”。 我可以在第二台PC上安装Vivado WebPack吗? 我在网站上给出的唯一选择是时间限制评估许可证。 感谢致敬, 大卫S. 以上来自于谷歌翻译 以下为原文 Hello, I have succesfuly installed Vivado WebPack license on my Windows PC. I would like noe to install Vivado on another PC but the license manager does not allow me to create a second license and I always stumble in the following error: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7a35t'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". Ho can I install Vivado WebPack on a second PC ? The only options I am given on the Web Site are time limited evaluation licenses only. Thanks and regards, David S. |
3个回答
@__daz__您只能使用您的登录生成一个webpack许可证,因此无法为另一台机器生成它。
-Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @__daz__ You can generate only one webpack license using your login hence no option to generate it for another machine. -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你好,
非常感谢你的快速回答。 这同样适用于ISE工具吗? 感谢致敬, 大卫 以上来自于谷歌翻译 以下为原文 Hello, thank you very much for your prompt answer. Does the same apply to ISE tool ? thanks and regards, David |
@__daz__yes
-Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @__daz__ yes -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3414 浏览 0 评论
2506 浏览 15 评论
2309浏览 1评论
649浏览 1评论
514浏览 1评论
2062浏览 0评论
790浏览 0评论
GMT+8, 2025-2-12 01:35 , Processed in 1.199521 second(s), Total 51, Slave 45 queries .
