扫一扫,分享给好友
我刚刚安装了Vivado Design Suite 15.2并下载了30天的评估许可证(当我获得许可证时,我点击了所有可用的软件包)。
许可证在状态下显示在许可证管理器中,但是当我尝试在Vivado中构建某些内容时,我收到以下错误: 错误:[Common 17-345]找不到功能'Synthesis'和/或设备'xc7k410t'的有效许可证。 请运行Vivado许可证管理器以获取有关确定哪些功能和设备已获得系统许可的帮助。解决方案:在Vivado许可证管理器中检查许可证的状态。 对于调试帮助,请搜索Xilinx支持“许可常见问题解答”。 主机在许可证上设置正确,下面是许可证状态的屏幕截图。 许可证状态不显示“合成”或“xc7k410t” - 是否应该? 评估许可证不包括“综合”吗? 以上来自于谷歌翻译 以下为原文 I just installed Vivado Design Suite 15.2 and have downloaded a 30-day evaluation license (I clicked on all available packages when I obtained the license). The licenses show up in the License Manager under status, but when I try to build something in Vivado I get the following error: ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7k410t'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". The host is set correctly on the license, and below are screenshots of the license status. The license status does not show "Synthesis" or "xc7k410t" - is it supposed to? Does the evaluation license not included "Synthesis"? |
3个回答
你好@niharjindal
在Tcl控制台中运行以下tcl命令后,还要共享生成的文件:report_environment -file env.txt 此文件提供有关您拥有的许可证的信息。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @niharjindal Also share the generated file after running the following tcl command in Tcl console: report_environment -file env.txt This file provides the information about the licenses that you have. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
谢谢您的回复。
当我尝试通过“立即连接”链接获得基于激活的许可证时,激活许可证全部显示为灰色,我看到消息: 下面的激活许可部分被禁用,因为Vivado License Manager未用于启动此Web会话,或者因为已使用此唯一请求ID生成激活许可证。 有关详细信息,请参阅许可证常见问题解答的“故障排除提示”部分.http://www.xilinx.com/tools/faq.htm 这是我第一次尝试获取评估消息,所以我不确定为什么我收到此消息。 以上来自于谷歌翻译 以下为原文 Thank you for your reply. When I try to get an activation based license via "Connect Now" link, the activation licenses all show up greyed out, and I see the message: The activation licensing section below is disabled either because Vivado License Manager was not used to initiate this web session or because an Activation license has already been generated using this unique request ID. Please see the "Troubleshooting Tips" section of the License FAQ for more information. http://www.xilinx.com/tools/faq.htm This is the first time I'm trying to get an evaluation message, so I'm not sure why I'm receiving this message. |
你好@ njindal2
您可以在Xilinx产品许可帐户的“管理许可”选项卡中查看一次吗?另外,根据vinay的建议,在Vivado tcl控制台中输入此命令并共享env.txt文件:report_environment -file env.txt 谢谢,Nupur 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @njindal2 Can you check once in your "Manage License" Tab of Xilinx Product Licensing account? Also, as per vinay's suggestion, type this command in Vivado tcl console and share the env.txt file: report_environment -file env.txt Thanks, Nupur Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
2597 浏览 7 评论
2922 浏览 4 评论
2376 浏览 9 评论
3475 浏览 0 评论
2554 浏览 15 评论
3090浏览 1评论
719浏览 1评论
597浏览 1评论
GMT+8, 2025-4-18 09:59 , Processed in 1.356294 second(s), Total 79, Slave 63 queries .
