我试图在远程操作模式(RS232 / RS422接口)中配置E4418B功率计。
我发送了几个命令,这些命令在E4418B的hte编程指南中给出。 遗憾的是配置没有完成。 例如,我手动配置了RS232端口的功率计,并发送命令“SYST:REM”,用于将功率计切换到远程操作模式。 每当我发送SYST:REM时,功率计显示屏显示“RX”一段时间而没有进入RMT模式。 如果任何人建议将功率计转换为RMT模式,我会很高兴。 我需要配置远程模式,需要通过RS232 / RS422读取功率电平。 提前致谢! 以上来自于谷歌翻译 以下为原文 I tried to configure E4418B power meter in remote operation mode (RS232/RS422 interface). I sent few couple of commands which are given in hte programming guide of E4418B. unfortunately the configuration not getting done. For example I have manually configured power meter for RS232 port and sent command "SYST:REM" for switching power meter into Remote operations mode. Whenever I sent SYST:REM, power meter display indicated "RX" for a while and not getting in to RMT mode. I would be nice if any one suggest any idea for turning power meter into RMT mode. Just all I need to configure remote mode and need to read the power levels through RS232/RS422. Thanks in advance! |
您好,以下内容可能有所帮助:常见问题解答+'是否有其他信息可以帮助我配置Agilent EPM-E系列功率计,通过RS-232与我的计算机进行通信?'+ http://www.home.agilent
的.com /安捷伦/ editorial.jspx CC = US&安培; LC =主机&安培; CKEY = 841474&安培; NID = -11143.0.00和ID = 841474。 真诚的,tsilchia 以上来自于谷歌翻译 以下为原文 Hello, The following may help: FAQ +'Is there additional information available to assist me in configuring my Agilent EPM-E Series Power Meter to communicate with my computer via RS-232?'+ at http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=841474&nid=-11143.0.00&id=841474. Sincerely, tsilchia |
1396 浏览 0 评论
2424 浏览 1 评论
2275 浏览 1 评论
2113 浏览 5 评论
3028 浏览 3 评论
1496浏览 1评论
840浏览 0评论
1259浏览 0评论
1399浏览 0评论
GMT+8, 2025-3-7 08:21 , Processed in 1.555231 second(s), Total 77, Slave 61 queries .
