嗨,我有一个带有MEB2板的PIC32 MZ2048 ECCM144启动器套件。现在我想尝试一些来自和声2.04的GFX演示,但这些演示都是针对EF部分的。谢谢!
以上来自于百度翻译 以下为原文 Hi, i have a PIC32MZ2048ECM144 Starter Kit with a MEB2 Board. Now i want to try some GFX Demos from HARMony 2.04 but these demos are all for the EF Parts. Exist a Tutorial or something to run these deos on the EC Parts? Thanks! |
3个回答
嗨,PIC32 MZ2048 ECM/ECH处理器在旧的V1.XX和声框架中被支持,但是由于它们不被推荐用于新的设计,所以它们从和声V2.xx中被移除。补充。EX版本中存在的许多硅bug已经被固定在EFX版本中,如果你做了一个真正的项目,那么你就应该真正订购PIC32 MZ EF启动器套件。如果你只想“玩”与和谐,如果你不介意使用旧版本,那么下载V1.11。支持ECX部分。
以上来自于百度翻译 以下为原文 Hi, The PIC32MZ2048ECM/ECH processors used to be supported in the old v1.xx Harmony framework but as they are not recommended for new designs, they have been removed from Harmony v2.xx. The significant difference is the ADC which is completely different and the floating point processor which has been added. Lots of silicon bugs existing in ECx versions have been fixed in EFx versions If you do a real project, then you should really order the PIC32MZ EF starter kit. If you just want to "play" with Harmony and if you don't care to use an older version then download v1.11. which supports the ECx parts. Regards |
你好,我现在得到一个PIC32 MZ EF启动器套件,尝试新的ARIL GFX功能。谢谢!
以上来自于百度翻译 以下为原文 Hello, i get now a PIC32MZ EF Starter Kit to try the new aria gfx feature. Thanks! |
嗨,这很有道理。ARIA提供了比以前的图形库更多的特性。新的PIC32 MZ…DA具有图形引擎和内部DRAM,提供了更高级的功能。
以上来自于百度翻译 以下为原文 Hi, That makes a lot of sense. Aria offers much more features than the previous graphics libraries. The new PIC32MZ...DA which has a graphics engine and an internal DRAM gives more advanced capabilities Regards |
5341 浏览 9 评论
2084 浏览 8 评论
1988 浏览 10 评论
3264 浏览 3 评论
2301 浏览 5 评论
846浏览 1评论
741浏览 1评论
683浏览 1评论
739浏览 0评论
629浏览 0评论
GMT+8, 2025-2-11 20:39 , Processed in 1.136815 second(s), Total 80, Slave 64 queries .
