大家好。
我已经安装了ISEsoftware -complete pack(我有Xilinx的官方公司许可证)。 在安装过程中我遇到了错误。 每次收到这条消息,我都会按“重试”。 我得到这个警告大约5次duting安装。 安装完成后,我运行ISE Design Suite 14.7并获取Clip Host主机窗口,就是这样。 安装文件没有损坏我检查了MD5总和,它们是相同的。 我正在安装到根目录C: Xilinx 目录中,所以没有不可接受的字符我没有使用。 谢谢。 伊万卡鲁纳斯 以上来自于谷歌翻译 以下为原文 Hello, all. I have installed ISE software - complete pack (I have the official company license from Xilinx). During the installation I got an error. Every time I got this message I pressed "Retry". I was getting this warning about 5 times duting the installation. After installation is finished I run ISE Design Suite 14.7 and get the Clip Host host window and that's it. Installation files are not corrupted I checked MD5 sum and they are the same. I am Installing into the root C: Xilinx directory, so no not acceptable chars I didn't use. Thank you. Ivan Carunas |
9个回答
嗨@ ivan.carunas,
只是有些疑惑。 您是否在安装过程中看到了内存要求? 您是否有足够的磁盘空间来安装。 你正在使用哪种操作系统? 你有C: Xilinx 14.7 ISE_DS ISE的读写权限吗? 谢谢,Arpan 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @ivan.carunas, Just have some doubts.
Thanks, Arpan Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
- 磁盘上有797 GBy的可用空间。
- Win7Pro - 我不改变写/读要求。 Xilinx软件在根C:中创建Xilinx directroy,并自行设置权限。 谢谢。 以上来自于谷歌翻译 以下为原文 - I have 797 GByte free space on the disk. - Win7Pro - I don't change the write/read requirements. Xilinx software creates a Xilinx directroy in the root C: and set permissions by themselves. Thank you. |
嗨@ ivan.carunas,
您的系统中是否有防病毒软件? 如果是,则尝试通过关闭防病毒软件来安装软件。 我怀疑某些程序正在锁定文件,因此无法提取。 我不确定它是否适合您,但您可以通过在关闭防病毒软件后安装软件来试一试。 谢谢,Arpan 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @ivan.carunas, Do you have any antivirus in your system? If yes then try installing the software by turning off the antivirus. I suspect some program is locking the file so it can't be extracted. I am not sure if it will work for you but you can give it a try by installing software after turning off the antivirus. Thanks, Arpan Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
切换它(迈克菲)。
无论如何出现错误。 我记得我试过一次关闭防病毒软件。 没有帮助。 现在也没有帮助(( 以上来自于谷歌翻译 以下为原文 Switched it off (McAfee). Anyway error appears. I remember I tried once to switch off antivirus. Didn't help. And now too, doesn't help (( |
另外,当我在PC1上安装这个ISE(即使有错误)时,我可以打开“提前计划”,但是当我打开我的项目时,我无法将XC3S50AN芯片分配给项目,并且最终编译它。
我在另一台计算机(PC2)ISE上安装了ISE,但是从那台计算机上无法编程到设备中。 我在PC2 MCS文件上生成,发送到PC1并成功编程。 所以情况很可怕。 一个PC2我只能编译和制作MCS文件 在另一台计算机上 - PC1我只能编程/闪存。 考虑到PC1是新安装的操作系统和一堆资源的新设备,这是不正常的情况。 除此之外的其他其他软件工作完美 我希望你能解决它。 谢谢。 以上来自于谷歌翻译 以下为原文 In additional when I installed on PC1 this ISE (even with errors) I can open "plan ahead" but when I open my project I cannot assign XC3S50AN chip to the project and esentially to compile it. I installed ISE on another computer (PC2) ISE, but from that computer cannot program into device. I take generated on PC2 MCS file, send to PC1 and succeed with programming. So the situation is terrible. One one PC2 I can only compile and make MCS file On another computer - PC1 I can only program/flash it. Is not normal situation taking into account that PC1 a new one with fresh installed OS and a bunch quantity of resources. Other other soft except this is working perfectly I hope you can resolve it. Thank you. |
我不能将XC3S50AN指定为不在FPGA列表中,而是自动更改为xc7vx485tffg1157-1
以上来自于谷歌翻译 以下为原文 I cannot assign XC3S50AN as not in list of FPGA but it changes to xc7vx485tffg1157-1 automatically |
嗨@ ivan.carunas,
xc7vx485tffg1157-1是默认设备,这就是自动分配的原因。 您可以尝试使用PlanAhead中的以下设置来搜索XC3S50AN吗? 谢谢,Arpan 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @ivan.carunas, xc7vx485tffg1157-1 is default device that's why automatically being assigned. Can you please try with the following settings in PlanAhead in order to search XC3S50AN? Thanks, Arpan Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
我明白但这些芯片在那里丢失了,否则我不会提出这个问题
以上来自于谷歌翻译 以下为原文 I do understand but these chips are missing there otherwise I would not rise this problem |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1357浏览 1评论
596浏览 1评论
460浏览 1评论
2013浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 01:44 , Processed in 1.417760 second(s), Total 92, Slave 76 queries .
