我最近在运行Vivado SDK试用许可证的计算机上激活了Zynq-7000Node锁定许可证。
在“Xilinx许可证管理器”下,声明Vivado SDK将在试用许可证到期后的7天内到期,但它不会显示我已激活的节点锁定许可证。 试用期结束后,Vivado SDK是否会转为使用节点锁定许可证? 附图显示仍在使用试用许可证的产品与使用节点锁定许可证的产品。 谢谢 以上来自于谷歌翻译 以下为原文 I've recently activated a Zynq-7000 Node-locked license on a machine that was running a trial license for Vivado SDK. Under the "Xilinx License Manager" it is stated that Vivado SDK will expire in 7 days, when the trial license expires, however it does not show the Node-Locked license I have activated. Will Vivado SDK roll over to using the Node-locked license once the trial expires? The attached images shows products still using the trial license vs those using the Node-locked license. Thanks |
8个回答
嗨,
日志文件显示有两个SDK功能。 一个来自试用许可证,另一个来自购买的许可证,见下文。 您需要在许可证管理器中向下滚动才能查看第二个SDK功能。 根据许可优先权,购买的许可优先于试用许可,将首先选择。 有关详细信息,请访问以下网址:http://www.xilinx.com/support/answers/44024.html 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, The log file shows that there are two SDK features. One is from trial license and other from purchased license see below. You need to scroll down in your license manager to view this second SDK feature. As per the license preceedence the purchased license has more priority than trial license and it will be picked first. Check this for more details http://www.xilinx.com/support/answers/44024.html Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
嗨,
您可以在Vivado tcl控制台中运行report_environment -file log.txt并在此处附加生成的日志文件吗? 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Can you run report_environment -file log.txt in Vivado tcl console and attach the generated log file here? Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
以下是具有许可软件的Node的日志文件。
log.txt 68 KB 以上来自于谷歌翻译 以下为原文 Here is the log file from the Node that has the licensed software. |
嗨,
日志文件显示有两个SDK功能。 一个来自试用许可证,另一个来自购买的许可证,见下文。 您需要在许可证管理器中向下滚动才能查看第二个SDK功能。 根据许可优先权,购买的许可优先于试用许可,将首先选择。 有关详细信息,请访问以下网址:http://www.xilinx.com/support/answers/44024.html 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, The log file shows that there are two SDK features. One is from trial license and other from purchased license see below. You need to scroll down in your license manager to view this second SDK feature. As per the license preceedence the purchased license has more priority than trial license and it will be picked first. Check this for more details http://www.xilinx.com/support/answers/44024.html Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,转到许可委员会。
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Moving to Licensing board.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨@prgdouglas,
你收到了所需的信息吗? 如果是,请通过标记解决方案来关闭线程。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @prgdouglas , Did you get the required information? If yes, please close the thread by marking the solution. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3415 浏览 0 评论
2506 浏览 15 评论
2315浏览 1评论
649浏览 1评论
514浏览 1评论
2062浏览 0评论
790浏览 0评论
GMT+8, 2025-2-12 16:12 , Processed in 1.515583 second(s), Total 89, Slave 73 queries .
